Tranny Temp Gage
Thread Statistics:     Users to Post: 3   |   Total Posts: 7   |   Total Views: 643
GOT8KIDS
• Rosemount, MN, USA
• Registered on 2/10/2005
• 19 posts
Posted:6/2/2005 06:55
My 02 V10 trany temp gage has quit working. I noticed yesterday morning shortly after pulling out of the garage that the gage was in the middle of the range and not low like it should have been. I have no idea how long it has been like this as I do not normally look to see if the trany is cold, but if it is hot. Funny, it never seemed to heat up even when pulling the travel trailer.
Any ideas on where to start to get this back to life? BTW it now has about 41k on it.
Thanks!
02' X V-10, Limited, 3:73, Stainless hood shield, DVD
Ozzie
• Kansas City Mo., MO, USA
• Registered on 5/20/2005
• 15 posts
Posted:6/2/2005 07:12
Check two things, the ground, if you have a wire ground, (I installed an extra wire ground, as my permatex thread pipe dope was so heavy, I did not have a good ground.)
Check the fuse and power to the gage.
Good luck.
Oz.
Posted:6/2/2005 07:22
And if you HAVE to replace it....
for goodness sakes get a REAL gauge...
not one like the on- off idiot gauge Ford gave us
edited 6/2/2005 07:22
GOT8KIDS
• 19 posts
Posted:6/2/2005 12:25
Ozzie, you are saying that the transmission temp gage has its own fuse in the fuse block? Also where is the sensor located on the transmission? Where did you add the extra ground?
JohnBoy, I did not know that the factory gage was that poor. Is it the sensor they use or the location of the sensor? I have to admit I am not that versed with the Transmission temp gage, but I have seen plenty of post in the last few years with people saying it should be in different locations of the loop as to what should be monitored like sump temp, out temp, and return temp. DO you suggest a pillar mount type of an addition to replace the factory gage?
Thanks for the replys!
Posted:6/2/2005 16:17
Got8kids...
if your Ex is hauling 10 people around,
then you should consider yourself "towing" already
and need a good temp gauge....
Many that HAVE put a tranny temp gauge report how
the factory gauge is more or less rated for three stages:
COLD
GOOD (maybe)
and
TOO LATE
I've not added a tranny temp gauge, but if you have to replace yours, I would consider a betta aftermarket one...
Ozzie
• 15 posts
Posted:6/2/2005 21:20
Sorry, I was assuming it was aftermarket. I installed a small hose clamp around the sending unit body, ground wire to the body from there.
I put in a B&G or some similar initials. Auto parts store. I cut the tranny cooling line and put their tee in. Works great.
GOT8KIDS
• 19 posts
Posted:6/6/2005 06:07
I was looking at the gage and it is just that an idiot light with a needle. 6 kids, two adults, 1 30' travel trailer, and it never moves. always in the center. It is down with the key off. turn the key on and up to the center and it never moves. Hills, stop and go, backing the trailer and it never moves. I will need to get the after market to watch it.
Thanks for the help!
Tranny Temp Gage
