Transmission fluid change. Gasser
Thread Statistics:     Users to Post: 3   |   Total Posts: 4   |   Total Views: 838
Paul Goulet
• Easthampton, MA, USA
• Registered on 1/29/2003
• 33 posts
Posted:6/7/2005 09:28
What is the correct way to have the transmission fluid ? I have read it should be pumped out and leave the filter in place.
Paul Goulet
Easthampton, MA
Posted:6/7/2005 15:08
Then how is the filter changed? I paid a shop to change mine ... drain fluid from the tranny and the torque converter (rotate the crank to get all of the fluid from the converter), blow out the lines to the fluid cooler, and replace the filter.
SZAlbNM
• Albuquerque, NM, USA
• Registered on 6/22/2005
• 13 posts
Posted:6/22/2005 14:18
Here's a link to a tech article on another forum.
http://www.ford-trucks.com/article/idx/0/057/article/Changing_ATF_Fluid_in_a_E4OD_and_4R100_transmission.html
Paul Goulet
• 33 posts
Posted:6/23/2005 15:50
Just got back from the ford dealer. Had the transmission service. They power flush the system and vacuum the system out. Gets all the old fluid out. Ford does not remove the filter, the flush and vacuum cleans it also.
Paul Goulet
Easthampton, MA
