Renegade wires...
Thread Statistics:     Users to Post: 3   |   Total Posts: 4   |   Total Views: 1559
Thekid
• Loveland, CO, USA
• Registered on 5/26/2005
• 67 posts
Posted:7/11/2005 20:05
Need a little help. None of my factory service manuals has a wiring diagram, only pinpoint tests in them.
Have a wire bundle under the dash that doesn't go anywhere. Can someone tell me what the wires are for?
Bundle has label "Connect to Instrument Feed" and the following numbers on the tag:
- F81B
- 14A348
- P260G
Has the following wire colors in the bundle:
- Green
- White
- Blue
- Red
- Brown
Also have 4 other wires that don't seem to have a home:
- Grey wire
- Black wire
- Yellow wire
- Grey w/blue tracer wire
- Set of RCA plugs (yellow & white)
The only thing I can think of is the previous owner had some sort of cell phone system in here, but I'm not sure what wires went where since the "de-installation" of the kit looks to be crap. Also wondering if maybe there was a brake controller in here, but again I don't know the wire colors.
Any help is appreciated. Thanks.
Posted:7/12/2005 08:19
What year is your Truck?
the later models have 5 stubbed up wires thru the firewall from the factory for "User Use".....
that way you don't have to punch a hole thru the firewall
just tie into either end with your wiring for whatever reason you want...
on edit though....
not sure that Ford would put an RCA plug in there though
edited 7/12/2005 08:20
Thekid
• Loveland, CO, USA
• 67 posts
Posted:7/12/2005 08:21
This is a 2000 Excursion Limited PSD.
Don't think these are "user use" wires.
ExcursionPSD
• Milwaukee, WI, USA
• Registered on 9/16/2004
• 26 posts
Posted:7/14/2005 01:56
I would say the bundle that says 'instrument feed' on it, could be the pigtail for an electric brake controller. There should be a plug on one end that goes into a receptacle up under the dash board, somewhat above the bake pedal.
2000 Excursion Limited born 11/99 4x4 Toreador Red ext./gray int. 7.3PSD, 3.73LS, Skidplates, Pwr/Htd TeleMirrors, 6CDchanger, HtdBuckets, LT265/75R16E Bridgestone Dueler A/T Revo, Ford Wraparound deflector, PSDV8 badging, RoofMarkerLights, Tekonsha Sentinel brake cntrlr, PCM=AXD0, WD 65hp chip, WalkerBigTruck Muffler, RS9000, Performance Friction 2 piece rotors/pads, Sylvania SilverStars, Landyot Gen III, Amsoil from MAXoil.com in diffs/trans/transfer 199k miles.
Renegade wires...
