How to Remove the 6-CD Player from the dash
Thread Statistics:     Users to Post: 4   |   Total Posts: 10   |   Total Views: 2674
Chuck Barlow
• Salem, VA, USA
• Registered on 5/19/2002
Posted:7/28/2005 15:45
Help- I have the 2001 Excursion Limited with the 6-CD/ Radio unit. I went out and bought some removal tools to take out the CD player so I could try and hook up the speed signal to the radio so I could use the speed sensitive volume control.
Well When I insert the tools- one on each side of the radio trrough the twin holes on each side:
The right side is stuck while the left side releases. I have spent too much time messing around and fear if I continue I will bend or break the radio unit.
Is there a secret way to remove these CD/radios in the Excursion. It almost seems that there is a latch or bolt holding in the right side.
Any comments or stories of success removing yours.
Posted:7/28/2005 16:14
When I insert the removal tools I put em in until you feel and hear a click which means they locked into place then apply outward pressure on the tool set while pulling the audio unit away from the instrument panel.
It may take a little bit of wiggling as dried soda/coffee liquids may have gummed up the contact areas around the stereo head unit,the bottom part of the head unit is on a dash mount slide bar track so it'll slide straight out and the same when re-installing it.
If you look just to the right of the plug in this PHOTO you'll see the track I'm referring to.
Bill.
HBJJAM
• Minneapolis, MN, USA
• Registered on 6/23/2005
• 93 posts
Posted:7/28/2005 17:57
Hope it comes out for you.
But now you have my curiousity on what you are talking about with the speed sensitive volume control?
Is this possible with a 2000?
I would love to have that option
any info from anyone would be greatly accepted
Posted:7/28/2005 18:36
Do you have the CD6 or the cassette/single CD model in your 2000?
HBJJAM
• 93 posts
Posted:7/28/2005 20:06
I have the in dash Cd/Cassette and the 6 disk changer in the console
Posted:7/28/2005 21:23
I haven't seen a modification as of yet to produce the speed sensitive volume feature on the cassette/single CD units.
Some CD6 units in the SuperDuties was not wired up for the speed sensitive feature but I do have a DIY to fix that.
Texas4x4
• Tyler, TX, USA
• Registered on 7/25/2003
• 289 posts
Posted:7/29/2005 11:14
Bill,
Where's the DIY fix you have? I need to check mine. I'm sure it's not working.
Kevin Curry
[email protected]
http://www.texas4x4.com
Posted:7/29/2005 11:43
Sure Kevin here's a Linky
Chuck Barlow
• Salem, VA, USA
Posted:8/2/2005 13:27
CHP, I know what you mean about the click. The problem is the right side tool slips out. I have worked on it so much that my hands get sore from trying.
That is why I asked if there was another permissive related to taking out the unit. From what you are saying, I am thinking the CD player was installed with a problem with the track. It seems jammed on the right side.
Thanks for posting the DYI install of the speed sensor input. I got the information from another site I like to visit.
Next I will try getting someone else that does this for a living to try and remove it.
Posted:8/2/2005 15:04
Sounds like the right side pressure release tabs are bent,jammed or something.
I dunno if you can reach the rear of the stereo from under the left side of the dash by the accelerator pedal area but if you can have a helper work the tool set while you try and push the stereo out from the rear,it has worked for me in the past.
It may take a side to side motion to get the release tabs past the cage.
