Newbie Has Questions
Thread Statistics:     Users to Post: 4   |   Total Posts: 6   |   Total Views: 476
DaBigHert
• Lindenhurst, NY, USA
• Registered on 8/19/2005
Posted:8/19/2005 20:25
Hello. My name is Anthony and I just puchased a 00 PSD X. I would like some tips on getting the best possible gas mileage. I know this has probably been done a million times, but I would appreciate doing it once more. Thanks
Eddie Henson
• Cordova, TN, USA
• Registered on 12/8/2004
• 122 posts
Posted:8/19/2005 22:05
Hi Anthony,
Welcome to the site!! Congrats on your purchase. As for improving the mileage on your X, replace muffler with a Walker BTM, Aeroturbine, or complete exhaust system; Replace the stock intake with aftermarket filter (AFE stage 1 or 2, Ford AIS, MAC, etc); get a mild chip/programmer or reflash your PCM with a different program. Their are many other things to do as well and I'm sure other members will offer some excellent suggestions. I would also recommend replacing your shocks (if your X is still riding on the originals) and installing a Hellwig sway bar for better ride control. Also, you may want to check out "The 5 Must-Do Things" for new excursion owners in the Article discussion topics. Hope this helps. Once again , Welcome!! Post up as often as you like with any questions. This is a great site and everyone here is willing to offer suggestions/help to get the most out of your excursion. . Almost forgot, replace your factory themostat with a 203 degree thermo and replace the t-stat housing
Eddie Henson
Posted:8/19/2005 22:16
Welcome as well !
Believe it or not, your right foot is the biggest abuser of the mpg calculation !
Secondly, check the air pressure in your tires and air them up as much as your bottom end can handle the ride !
Third, check/change your fuel filters...
the 7.3L X is capable of suprising good highway mileage if driven with that in mind...
good luck,
J
Douglas Dircks
• New Richland, MN, USA
• Registered on 11/13/2003
• 118 posts
Posted:8/19/2005 23:23
Keep it under 2,000 RMP's or 68 MPH and you will get 20 mpg on flat land all day long empty.
Eddie Henson
• Cordova, TN, USA
• 122 posts
Posted:8/20/2005 22:24
Eddie Henson
Eddie Henson
• Cordova, TN, USA
• 122 posts
Posted:8/20/2005 22:28
True, JohnBoy, very true. But, once you start adding things and seeing what it does to your X, you don't want to stop . Unless, of course, you have to start explaining to the Mrs. why there is an $xxx charge on the Visa to something-or-other diesel.com
Eddie Henson
