ABS Light
Thread Statistics:     Users to Post: 4   |   Total Posts: 7   |   Total Views: 3348
Mark Peterson
• Big Lake, MN, USA
• Registered on 12/29/2004
• 25 posts
Posted:9/18/2005 21:43
Hello, I was driving my 01 PSD X today and came to a frequent stop at a stoplight. After doing so,
the ABS light has came on, and stayed on! Lookin for advice! Thanks
Mark
Posted:9/18/2005 21:46
Mark
Based on my experience if nothing else is acting up it could be the VSS (Vehicle Speed Sensor) which is installed on top of the rear axle housing,check and make sure the connector is snapped in securely as it can pop loose if bumped by the sway bar or knocked loose by other means.
rozett
• Limington, ME, USA
• Registered on 1/10/2003
• 163 posts
Posted:9/19/2005 11:23
If you've checked the connection and it looks solid, you may need to replace the sensor. It costs about $16 and takes only five minutes to change.
//bruce
edited 9/19/2005 11:23
Posted:9/19/2005 14:51
A bad VSS will also give drivability problems. Speedo acting weird, erratic shifting etc. etc.
If you don't have those problems, I wouldn't suspect it and would have the PCM scanned for codes (they get stored when the light lights up)
I would also check your brake fluid. Why?? Heck, I don't know...but it should always be the first thing you do. That; and just open the hood and look at the engine.
rozett
• 163 posts
Posted:9/20/2005 10:55
Ken, I had to replace mine a month ago. I drove around with the ABS light on for a month before I got around to replacing it. I had no driveability problems that I noticed. I even delivered a couple loads of wood, so I pulled the heavy trailer without incident. Light went out as soon as I replaced the VSS.
//bruce
Posted:9/20/2005 11:26
Ditto,no driveability issues either when ours became unplugged in August 2003 while in Phoenix
I had to reset the ABS lamp and that was it
Posted:9/20/2005 20:13
Well I'll be daggum!
ABS Light
