Help-Water in Fuel Indicator
Thread Statistics:     Users to Post: 3   |   Total Posts: 9   |   Total Views: 665
RussellExcursion
• Los Angeles, CA, USA
• Registered on 4/4/2005
• 33 posts
Posted:11/12/2005 09:23
Last night the "Water in the Fuel" indicator came on. In the owner's manual it says to empty some fuel bowel (I dont have the manual in front of me).
Not being a mechanic, is this a hard procedure or is this something I should let the local mechanic handle. I'm about 6 miles away from my local Ford dealer and don't want to drive that far with gas in the tank. The local mechanic is only a mile away.
Ideas? Advice?
Bowden Russell
2002, 7.3L.
Posted:11/12/2005 09:43
On top of the engine there'll be a black plastic cover that has Powerstroke on it,just behind/under it is a canister with a black lid,that'll be your fuel filter/water separator unit.
Viewing from the front there'll be a Yellow plastic lever on the rear leftward side,turn that lever clockwise 45 degrees(it's limit) for about 5-10 seconds to drain off the water on the bottom of the bowl.
Most owners as well as myself takes about 3' of 3/8" ID hose(should be the size) and slips it onto the bottom of the steel drain line coming down from the bowl it'll be somewhat a bear to reach but not impossible,then the other end into an empty motor oil bottle to avoid diesel from running down your driveway.
RussellExcursion
• 33 posts
Posted:11/12/2005 15:27
Bill,
Thanks for the information.
That was a very easy problem to solve! Nothing as nice as seeing that light go off!
Thanks again,
Bowden
glenn z
• harrison twp., MI, USA
• Registered on 8/22/2003
• 63 posts
Posted:11/16/2005 14:43
a while back i had seen a source for the repqair kits for the o-rings for the valve, anyone remeber whom it was,
i am going to change fuel filter soon and know that when i turn the valve it will leak, leaked once already and rigged it to work until new rings obtained
glenn z
www.mtrperformance.com
Posted:11/16/2005 16:02
glenn z
Here ya go Glenn BCC
glenn z
• 63 posts
Posted:11/17/2005 08:28
maybe a bad thing i went to their site, found a few other items that i am going ot purchase
thanks for the info
glenn z
MTR Performance
Posted:11/17/2005 08:39
Yeah watch out for Garrett,he's a great salesman
I'm going to pick up the new Steriod package he now carries to stack/replace my SCMT 1700
glenn z
• 63 posts
Posted:11/18/2005 14:23
seen that, one of the things on my wish list, or looking at the dp tuner 80 hp chip from jody....
let me know how the steroid works out, you going with steroid or steriod T
correct me if i am wrong buit basicly it sound like it mainly changes fuel pressures, is that what i am reading into it here...
glenn z
MTR Performance
Posted:11/18/2005 16:21
I'll probably get the Steroid T to stack on the SCMT 1700 or use standalone.
