aftermarket nav
Thread Statistics:     Users to Post: 5   |   Total Posts: 13   |   Total Views: 1479
dag
• Sewickley, PA, USA
• Registered on 1/6/2006
• 13 posts
Posted:1/7/2006 19:27
So I have an Ex coming in the next couple of weeks (04) I would like to repalce the standard 6-disc radio with an in-dash nav system- also has the DVD overhead
There seems to be some interface between or among the DVD, 6disc radio and the controls
on the steering wheel - I can't figure what
SPECIFIC QUESTION: #1 - if I rip out the 6 disc, cut the wires to the DVD etc, will the DVD
still workas a stand-alone system???????????
i.e. - the back seaters can have their DVD, use the headphones, etc ???????????
NOTE - I have a Garmin Streetpilot - not what I want - looking at a 2-Din, in dash unit?
Bill Johnson
• Rio linda, CA, USA
• Registered on 6/11/2002
• 201 posts
Posted:1/8/2006 01:05
Ok, here's what your looking at.
First off the DVD, I assume that you have to tune it to a radio station. If thats the case, then going to an aftermarket headunit is a snap.
Second, streeing controls will require an interface to work with an aftermarket deck, depending on make and model. Also easy.
Finaly, your Radio size is 1.5 DIN. Some brands make a deck to fit that size. JVC, Kenwood, and Alpine. Alpine is releasing one this year. Most people will run a standard DIN unit with a install kit that will give you a pocket under the deck. Pioneer and Alpine both make killer navi systems for there decks.
I myself have the Alpine 901 flipout deck and run my video back into my factory DVD through the rca's. This will allow you to still have rear controls and headphones
Yahoo IM - kingsuv00
200Proof
• Houston, TX, USA
• Registered on 10/9/2004
• 28 posts
Posted:1/8/2006 02:56
I have an 04' X as well with the factory DVD and have changed out the 6 disc headunit with the Eclipse AVN5495 Nav unit. It's an awesome unit with Nav, DVD & a hard drive that you can store 3,000 songs. I like the double din units better than the flip out screens, they look less aftermarket. Everybody that has seen my setup thinks it looks like a factory Nav, which is what I was trying to achieve.
You can keep the factory DVD but the audio will be through the headphones only & the installer will have to tap into a power lead for the video screen. Right now I'm using the PAC Audio SWI-X steering wheel interface to work the steering wheel audio controls, it works pretty good but can be glitchy at times. Pac just came out with the SWI-ECL which plugs into the Eclipse units rather than using IR signal & eliminates the glitches with the SWI-X, mines on order.
Here are some pics:
http://community.webshots.com/myphotos?action=viewAllPhotos&albumID=527332550&security=HJPALv
2004 Excursion Limited - Black, 6.0 PSD, 4x4
3" Donahoe Racing lift w/ B code rear springs, Pro Comp Xtreme Alloy 6005 wheels & 315/70/17 tires, Donahoe Racing Signature series shocks, Rancho steering stabilizer, Landyot Radius Rods, 30mm rear sway bar, billet grill w/ black Ford emblems, Prodigy brake control, K-40 front & rear radar detector, Eclipse AVN5495 Nav/DVD w/ back-up camera, PAC Steering wheel Interface, Dynaudio 240 MKII components, JL Audio XR-650 CSi components, JL Audio XR-650 CXi, JL Audio Stealth Box 300w sub, JL Audio 450/4 amp, (2) JL Audio 300/2 amps, Clifford G5 alarm, SCT Xcal2 w/ Innovative Diesel Tunes & Edge Attitude Monitor
http://community.webshots.com/user/200Proof
dag
• 13 posts
Posted:1/8/2006 13:06
Thanks to BJ and 200P
Lets see if I have part 1 correct -
If I take out the factory 6 disc, the factory DVD in back will still work as a 'stand-alone'
unit and will only play audio through the headphones
I will also have to find power from another source - does this mean that I can
unplug the existing wire from 6 disc IN THE DASH of will I have to tear up the headlining?????
Still a little confused - BJ says 1.5 DI N and 200P decsribes as 2 DIN or double Din ????
200P - could not access your pictures??
dag
Bill Johnson
• 201 posts
Posted:1/8/2006 13:39
You won't have to cut anything just unplug it.
As far as deck size, you can have a dbl din with a little triming to the opening at the top and bottom. (very) little. Then fab some trim to hide the slight gap on the sides. Also very little. if the DVD unit comes with an aux video & audio out, then you could back feed the sound into your deck.
Ace
• Malibu, CA, USA
• Registered on 10/27/2005
• 54 posts
Posted:1/10/2006 10:28
Hey 200proof, I cannot access that link....I'm really interested in seeing that install. I just installed my Sirius starmate and Ipod and it works great with the factory 6 disc in dash...but in about a year or so, I would like to attempt something like this.
200Proof
• Houston, TX, USA
• 28 posts
Posted:1/10/2006 22:57
For pictures of the Eclipse AVN5495 try going to www.webshots.com, then go to community & at the bottom of the page you can "find a member" type in 200Proof and it should bring up my photo album.
dag
• 13 posts
Posted:1/13/2006 10:29
200Proof
You are indeed a wizard
I finally was able to access your photos - what a clean install
If I'm looking correctly, you have some kind of trim around the nav unit -
did you fab it or what?
Also two quick questions-
Are you using the stock Ford antenna or is there some other
that works better? Primarily interested in the nav.
I believe the mapping information on the Eclipse is factory loaded
on the hard drive - how do you upgrade as new info becomes
available?
Thanks for all the info - you really have a great ride
dag
Posted:1/13/2006 12:07
here's a shortcut to his pics:
Nice ride - looks a lot like my 03 Ex I traded in !!!
cept newer, and nicer, and .....
just teasing - but might clean off the peanut butter fingerprints next time you take a close up
edited 1/13/2006 12:12
200Proof
• Houston, TX, USA
• 28 posts
Posted:1/13/2006 23:54
Dag,
Thanks, I love the truck & yes, I am using the stock antenna for the stereo, the nav has its own antenna which I have mounted under the plastic piece where the windshield wipers are. The map is factory loaded and updates will be via memory stick from what I've been told. The trim piece around the hu was fabricated buy the guy that did the install, at first we tried one from a kit but it didn't fit very good so he made his own.
aftermarket nav
