X squats in the rear when connected to travel trailer.
Thread Statistics:     Users to Post: 5   |   Total Posts: 6   |   Total Views: 889
JWandVassie
• Leesburg, FL, USA
• Registered on 9/14/2005
• 10 posts
Posted:3/1/2006 13:49
On my 4th and unfortunately last X. Have the 05 PSD. A problem with this one is the same as with the previous 3. I pull a 10,000 lb Travel Trailer with a weight distribution hitch. No matter how I adjust the hitch, the X squats more in the rear than other tow vehicles I have used; namely, a 3/4 ton Suburban and 1 ton dually. The X pulls the trailer fine with no adverse effects. I just don't like the looks of the X squatting in the rear.
I would like for the X to be level with the trailer connected.
Suggestions please.
docgas63
• Sugar Land, TX, USA
• Registered on 8/20/2005
• 37 posts
Posted:3/1/2006 14:17
had EXACT same situation.... driving the 3/4 ton suburban for 3 years and moved to 05 PSD...
After much research, finally just installed an "add a leaf". Rear was raised 2 " and sits totally level with my 9000 lb RV with a 1000 lb tongue weight attached.
DG
David, Sandra and 3 Kids
2005 4x2 6.0L PSD Excursion Limited
Sunnybrook 3310
Hensley Arrow - Prodigy
SuperChips, X-Monitor, Zoodad, PSD Badges
gawent
• Registered on 3/2/2005
• 65 posts
Posted:3/2/2006 10:39
Do you have a 4x4 or a 4x2? I have an 04 4x4 X and had the same issue. I installed Timbren Load Boosters in place of the stock yellow snubbers. I know they worked good for me but not sure on a 4x2. For me it was either those or airbags. Timbrens were cheaper and easier to install. Took about 1 hour at best. I have pix of them here:
ps. the pix in the sig is pre-Timbrens
BigStrokerX
• San Diesgo, CA, USA
• Registered on 12/23/2004
• 9 posts
Posted:3/4/2006 00:08
The X has softer springs than the f250 or 350. I tow a 9500# trailer and I wouldn't even imagine doing it without airbags. Do yourself a favor and look into some. You'll be glad you did.
BSX
JWandVassie
• Leesburg, FL, USA
• 10 posts
Posted:3/5/2006 15:44
Thanks for the replys. I've decided to go with the airbags because I like the ability to adjust the lift according to the load being towed. I've found the Firestone airbags for about $245 and the controller for about $190. Any thoughts on these or other airbags??
Thanks again.
05 X PSD 2WD
02 29RLSS Salem TT
00 32' Party Cruiser converted to houseboat
XFanatic
• Sunny Miami, FL, USA
• Registered on 2/24/2006
• 10 posts
Posted:3/6/2006 17:42
I have a set of Firestone air bags installed on my 3/4 ton p/up. I've had them for about 3 years and they are awesome. Just the other day I loaded a pallet and a half of cement 90 bags at 60lbs each. You do the math. The guy at Home Depot freaked out. Fortunately I didn't have to go far cause my tires were maxed out. I also bolted up a 3 gallon tank in between the airbags and compressor to hold air for either filling tires or my air horns. I hope this helps.
