Fuel Question
Thread Statistics:     Users to Post: 3   |   Total Posts: 4   |   Total Views: 553
David Rush
• Greenville, SC, USA
• Registered on 4/11/2004
• 233 posts
Posted:3/8/2006 19:19
A buddy of mine has a new 05 X and has about 8K miles on it. For some reason, the "Water in Gas" light keeps coming on but the engine runs fine. He had one fuel filter bled--twice. Still did the same thing. I know there is a second filter but I was wondering if anyone had any experience with this particular quirk. I have a V10 so I am no help.
Thanks!
David
docgas63
• Sugar Land, TX, USA
• Registered on 8/20/2005
• 37 posts
Posted:3/8/2006 19:25
I have an 05 also, and the exact same thing happens. I had the sensor changed 2x at the dealer and still is happening. I use only Exxon or Chevron diesel. I no longer know what to do either and I am getting tired of bleeding the fuel filter.
anyone?
dg
David, Sandra and 3 Kids
2005 4x2 6.0L PSD Excursion Limited
Sunnybrook 3310
Hensley Arrow - Prodigy
SuperChips, X-Monitor, Zoodad, PSD Badges
Posted:3/9/2006 08:16
You do know there is two fuel filters... right ? one on top and one inside the drivers side frame rail...
(on edit - just saw your stmt that u know about 2 filters Dooh )
Draining is great periodically, but if you get a batch of bad fuel, you may ruin a filter or two...
Also the 03's had a recall on the HFCM (the bottom filter housing - WIF sensor), take it into the dealer and ask them if the 05's have the same issue....
(My 05 hasn't had a problem, but I jsut turned 15,000 miles....)
Good Luck !
edited 3/9/2006 08:17
docgas63
• 37 posts
Posted:3/9/2006 09:35
JohnBoy,
I realize that there are 2 filters but as I remember reading the owners manual, I believe it states that if the water light goes on, you drain the drivers frame fuel filter. That is where the sensor is... Thus should it OR does it make a difference about the other fuel filter if there is no sensor there and the book does not mention it?
dg
Sunnybrook 3310
Fuel Question
