How do I change door code
Thread Statistics:     Users to Post: 3   |   Total Posts: 4   |   Total Views: 766
cpditty
• Rogers, MN, USA
• Registered on 3/27/2006
• 10 posts
Posted:3/27/2006 16:30
I have my door code for my 03 X but I want to change it. Does anyone know how to do this?
rozett
• Limington, ME, USA
• Registered on 1/10/2003
• 163 posts
Posted:3/27/2006 18:42
This is quoted from my '00 Owner's Manual....
To program your own code:
1. Enter factory set code (keypad will illuminate when pressed).
2. Press 1/2 control within five seconds of step 1.
3. Enter your personal 5 digit code. Enter each digit within five seconds of previous one.
Do not set a code that includes five of the same number or presents them in sequential order. Thieves can easily figure out these types of codes.
Your personal code does not replace the permanent code that the dealership gave you. You can use either code to unlock your vehicle. If a second personal code is entered, the module will erase it in favor of the new code.
If you wish to erase your personal code, use the following instructions:
1. Enter factory set code.
2. Press 1/2 control within five seconds of step 1 and release.
3. Within five seconds of step 2, press and hold the 1/2 control for two seconds. The system will now only respond to the factory set code.
//bruce
edited 3/27/2006 18:43
Posted:3/27/2006 18:46
From the manual;
1. Enter factory set code (keypad will illuminate for five seconds when a
key is pressed).
seconds of step 1.
of previous one.
new code.
two seconds.
cpditty
• Rogers, MN, USA
• 10 posts
Posted:3/28/2006 07:36
Damn I like this Forum... You guys rock!
