Front springs
Thread Statistics:     Users to Post: 3   |   Total Posts: 11   |   Total Views: 2124
rush2112
• athens, GA, USA
• Registered on 3/28/2006
Posted:3/28/2006 12:59
I have an 01 X V10 4X4 limited with 100k miles that the drivers front sits 3/4" lower than the passengers side. When I hit a bump or come out of my driveway the passenger side feels like it has good dampening but the drivers side is VERY stiff. I have replaced the shocks with Rancho but this didn't help much. I have had a dealer tell me that maybe my spring has sagged. I have a local offroad shop that takes off springs from F250's all the time and says that he can get me a set for next to nothing. He says that they are a little stiffer that the stock X springs and should sit the truck back up to where it started. Is this the case? What spring code should I be looking for? Should I just purchase new springs from Rancho or one of the other aftermarket vendors and be done with it? Thanks for your help.
Posted:3/28/2006 14:16
Actually the 4x4 Excursions come from the factory with sagging springs(Ford Engineering) and almost always hits the bumpstops which is the negative ride you're experiencing.
If you're not going to install a heavy bumper on the front like on mine I say go with the V code springs
We upgraded the springs on our X just a few months after we took delivery
rush2112
• athens, GA, USA
Posted:3/28/2006 14:33
Would I use the same as you did even though I have the V10?
Posted:3/28/2006 14:59
With the V-10 it should be around 1/4" higher than the 7.3L Powerstroke but it should be perfectly fine
edited 3/28/2006 15:00
Scott Stover
• Fayetteville, NC, USA
• Registered on 4/16/2004
• 354 posts
Posted:4/1/2006 16:56
Bill's got one sweet Ex, the V's will be fine for the V-10, if you really want to go up, go with X codes, they are the bomb!!
2000 X 4x4 V-10 4.3 LS
K&N
Gibson Catback
"Custom" Kickplates
Posted:4/1/2006 19:11
Come to mention it if you just want to gain 1"-2" lift on the front I highly recommend the Edge Mini Spring Pack Kit. They run about $225 & come with everything needed and can be knocked out in your driveway,even easier if you have air tools
Scott Stover
• 354 posts
Posted:4/15/2006 23:02
I have thought about those...Do they really make that much of a difference?
K&N
Gibson Catback
"Custom" Kickplates
Posted:4/16/2006 10:25
To bring up the front end and provide additional oversized tire clearance I say they work well.
Scott Stover
• 354 posts
Posted:4/16/2006 19:50
Sweet! Thanks Bill!
K&N
Gibson Catback
"Custom" Kickplates
Posted:4/16/2006 20:01
I may go the spring pack route versus going to W code springs due to the labor time involved alone
Front springs
