Fuel separator on the '05 - Where's the Lever??
Thread Statistics:     Users to Post: 3   |   Total Posts: 5   |   Total Views: 535
SISK
• Currently living in Saltillo, XX, Mexico
• Registered on 4/1/2006
Posted:4/4/2006 21:12
Hi guys, first post on the forum. I've been reading through your posts of wisdom and experience, and have come across some wise (and otherwise) suggestions.
Question is: Where's the lever on the HFCM (frame mounted fuel filter)???
I've searched previous posts on the forum but haven't found anything helpful for this model.
The supplemental diesel engine manual for my '05 EX states that there is a lever on the frame mounted filter / separator. This lever should be opened to drain water in the filter.
HOWEVER - I can't locate the lever. I can see the filter module plain as day, but I don't see any lever. What am I missing here (besides a lever)???
What is the correct method for draining water from the fuel?
SISK
Flashlight - a cylindrical tube for storing dead batteries
'05 Limited - Stock for now
docgas63
• Sugar Land, TX, USA
• Registered on 8/20/2005
• 37 posts
Posted:4/4/2006 21:51
its not a lever, it is the allen wrench hole. I had the same issue when I tried the first time.
dg
David, Sandra and 3 Kids
2005 4x2 6.0L PSD Excursion Limited
Sunnybrook 3310
Hensley Arrow - Prodigy
SuperChips, X-Monitor, Zoodad, PSD Badges
Posted:4/5/2006 07:30
Welcome aboard SISK! Great to have you with us on FordExcursions.com
Click on THIS LINK and scroll down to post #3.
Check your local Ford dealer for the new plug or goto PowerStrokeShop
The HFCM plug should take a 6mm Hex wrench but be careful when tightening it up it can be easy to strip which is why most owners have been upgrading to the larger steel part with a thumbwheel which eliminates the need for the allen wrench
The little stock one is on the right the newer revised on the left.
edited 4/5/2006 07:31
SISK
Posted:4/5/2006 20:38
Thanks for the replies Docgas and CHP, I appreciate your input.
so if there isn't a a lever on the fuel separator, does that mean the usermanual is mis-printed?
Is there another location in the engine compartment where you can also drain water from the engine mounted fuel filter?
SISK
Never underestimate the power of idiots in large groups!!
Posted:4/5/2006 21:42
On the 7.3L PowerStroke Diesel's fuel filter has a drain lever on the top side of the enigine.
The 6.0L you only drain the HFCM so you can change the HFCM fuel filter and the top engine mounted fuel filter,sounds funky but thats the way International and Ford designed it
