Changing Convience Light??
Thread Statistics:     Users to Post: 3   |   Total Posts: 11   |   Total Views: 1097
6LMonster
• Wake Forest, NC, USA
• Registered on 1/30/2006
• 29 posts
Posted:4/13/2006 13:38
Okay guys, how do you change the light bulb in the convience/map light over the rear seats?? They are embedded into the headliner and I don't want to just pull it out and ruin the light or headliner.
Thanks!
2005 X Limited, 4x4, 6.0L PSD
Posted:4/13/2006 16:32
If you're referring to the large center courtesy lamp set the lens itself pop's out for bulb replacement.
Now if it's the smaller individual courtesy lamps take a small screwdriver slide it between the lamp assembly lip and headliner then gently push in to release the locking tab(switch end) and the lamp assembly should pull down to get to the bulb.
edited 4/13/2006 16:33
6LMonster
• 29 posts
Posted:4/13/2006 19:08
Bill,
Actually I am talking about the little ones for the second row. They are about the size of a quarter or half-dollar...
I might need to go out and take a picture of it......
Posted:4/13/2006 19:47
I did a quick how-to for ya 6L,give it a looksee lemme know if it helps some.
How-to Link
edited 4/13/2006 19:47
Bill Johnson
• Rio linda, CA, USA
• Registered on 6/11/2002
• 201 posts
Posted:4/14/2006 01:03
Hey sorry for the slow post on this one but if you use a pick on the lens it will pop right out and won't wear out the thin headliner. I replaced all mine with LEDs
Yahoo IM - kingsuv00
6LMonster
• 29 posts
Posted:4/14/2006 07:08
Bill and Bill,
Thanks that link was what I needed!! I just didn't want to destroy anything.
Also, the other Bill, where did you get your LED's from? Are they just as bright, maybe a little brighter??
Bill Johnson
• 201 posts
Posted:4/14/2006 09:05
http://www.superbrightleds.com/
A little warning one can go broke like I did changing them all out. They are a lot brighter and I don't worry about one getting left on over night.
Posted:4/14/2006 09:08
Which one did you order? How did you do the conversion?Was it plug and play or did you have to break out the soldering iron,etc?
Bill Johnson
• 201 posts
Posted:4/14/2006 19:00
Plug and play it's as easy as finding the right size auto bulb with the right base and your golden. i did every light in the truck
Posted:4/14/2006 19:02
Aww comon Bill you're not making it easy for us
