Transmission Selector
Thread Statistics:     Users to Post: 2   |   Total Posts: 3   |   Total Views: 485
aobrien
• Winchester, VA, USA
• Registered on 6/3/2005
• 30 posts
Posted:7/15/2006 07:43
Once in a while, after I put the truck in park and shut it off, it won't restart unless I reset the transmission selector (i.e. pull it down into drive and then put it back up into park). What is the most likely culprit for this symptom? Thanks.
Andy
2000, 6.8L, Limited
Posted:7/15/2006 18:38
I'd have to lean to linkage is in need of adjustment or repair,the Digital Transmission Range (TR) Sensor could also be in need of adjustment.
I had a similar issue with our 99.5 F250 7.3L which exhibited the same issue you're having with the X.
aobrien
• 30 posts
Posted:7/16/2006 06:29
Thanks for the feedback, Bill. I'll go check it out.
Andy
