Anti-Sway bar noise
Thread Statistics:     Users to Post: 2   |   Total Posts: 2   |   Total Views: 483
David Rush
• Greenville, SC, USA
• Registered on 4/11/2004
• 233 posts
Posted:7/24/2006 06:43
Has anyone had noise from the Helwig ant-sway bar when you go over--say a speed break in a parking lot. It's a bit of a squeaking sound. I understand they need to be lubricated???\
David
aklim
• Hartford, WI, USA
• Registered on 2/20/2006
• 133 posts
Posted:7/24/2006 08:46
No noise. However you can try disaassembling it and puting grease on the bushings if you want. I didn't.
Anti-Sway bar noise
