Brake Controller
Thread Statistics:     Users to Post: 4   |   Total Posts: 6   |   Total Views: 689
HBJJAM
• Minneapolis, MN, USA
• Registered on 6/23/2005
• 93 posts
Posted:7/24/2006 08:31
Needing to put one in.
What to get?
And is it a DIY job? I have the factory 7 plug in the back. There is a wire harness on the firewall too
aklim
• Hartford, WI, USA
• Registered on 2/20/2006
• 133 posts
Posted:7/24/2006 08:45
Pretty much DIY. Get a Tekonsha Prodigy and the correct harness from Tekonsha and install.
Jay Hanratty
• Millbury, MA, USA
• Registered on 8/13/2004
• 35 posts
Posted:7/24/2006 08:51
Hi
Just as the previous post said, get a Prodigy and the adapter harness , plug and play!
The adapter harness simply plugs in up behind the lower dash panel, near the back side of the radio, not alway's the easiest to see or find , but it will be there!
Jay
HBJJAM
• 93 posts
Posted:7/24/2006 08:55
thanks guys
I see the wires on top of the fuse panel on the drivers side firewall, well at least I am assuming these four are for the brake controller.
I will look up under the dash
BTW, this is a 2000 V10 Limited in case anything has changed on this
did some reading on this unit.
It will not work for my future plans
I am looking at upgrading my Boat trailer brakes from Surge Hydraulic to Electric over Hydraulic and the Prodigy sites states this will not control that type
NEXT
edited 7/24/2006 09:06
Jay Hanratty
• Millbury, MA, USA
• 35 posts
Posted:7/24/2006 11:48
Hi
Don't concern yourself with the four wires up by the fuse panel at the firewall, everything you need is inside by the left hand rear corner of your radio, square lt grey electrical plug. If you buy the prodigy and the correct adapter harnes it's a 10 minuete install, easiest DIY project you'll ever do!
ExcursionPSD
• Milwaukee, WI, USA
• Registered on 9/16/2004
• 26 posts
Posted:7/27/2006 17:00
listen to Jay, about using the plug-in located in the area behind the radio.
The four customer usage wires near the fuse panel are for a different purpose entirely and won't help you with your brake controller.
2000 Excursion Limited born 11/99 4x4 Toreador Red ext./gray int. 7.3PSD, 3.73LS, Skidplates, Pwr/Htd TeleMirrors, 6CDchanger, HtdBuckets, LT265/75R16E Bridgestone Dueler A/T Revo, Ford Wraparound deflector, PSDV8 badging, RoofMarkerLights, Tekonsha Sentinel brake cntrlr, PCM=AXD0, WD 65hp chip, WalkerBigTruck Muffler, RS9000, Performance Friction 2 piece rotors/pads, Sylvania SilverStars, Landyot Gen III, Amsoil from MAXoil.com in diffs/trans/transfer 199k miles.
Brake Controller
