Hellwig Install Difficulty on 2005 4X4 Excursion
Thread Statistics:     Users to Post: 4   |   Total Posts: 11   |   Total Views: 3198
Maxx_001
• Florence, SC, USA
• Registered on 8/15/2006
• 9 posts
Posted:9/13/2006 07:40
I just installed my new LANDYOT Radius Rods last weekend. I also tried to install the Hellwig Anti-Sway bar but the hardware that I received seems incorrect. Is my 2005 4X4 that different from previous years??? Hellwig's catalog says the bar will work on 2000-2005 models. The supplied U-Bolts would not fit in the rear shock mount brackets. The diameter of the U-Bolts are too large to fit through the holes. I found that the stock U-Bolts will work, but they are of a smaller diameter material, so I am not sure this would be a good solution, as installing the anto-sway bar will be introducing more force upon them. Also, the end link bolts will not fit in the existing frame holes. I am going to have to drill them out. I did not have a right angle drill to use so I was out of luck. On the passenger side, the muffler interferes with drilling. I was a little dissapointed in this, as I will now have to unbolt the radius rods in order to install the anti-sway bar. I emailed Hellwig and am awaiting an answer. Any advice would be appreciated.
edited 10/6/2006 07:25
Jetfixr
• Orange County, CA, USA
• Registered on 1/27/2002
• 45 posts
Posted:9/13/2006 17:41
I thought I read somewhere to install the swaybar first. The U-bolts diameter is too big how? Will one end fit through a hole. Or, will they not fit in the holes at the same time? I laid out everything on the floor with the hardware before I started. I remember the Hellwig directions are horrible. Make sure you have the right hardware and the correct loacation for the bolts. I didn't have to drill or cut anything.
Jerry
2000 Excursion Xlt 4X4 6.8L, 4.30LS, Grey Leather, RS9000's, Hellwig swaybar, 10.4" video w/vcr.
Maxx_001
• Florence, SC, USA
• 9 posts
Posted:9/13/2006 17:56
Yeah, I did try to install the Hellwig first. Everything fits together fine on the floor. It just doesn't bolt up. to the Excursion. I ended up putting the Radius Rods on anyway, even though I know I have to unbolt 1 end in order to install the Hellwig if/when I get the right hardware or drill out the holes.
Maxx_001
• Florence, SC, USA
• 9 posts
Posted:9/13/2006 18:02
Also, the U-Bolts are too "wide"- i.e. the space between the threaded ends is too great thus they do not properly align with the shock mount holes. They are not bent or anything, they are just too wide. In addition, the actual diameter of the U-Bolt threaded ends are too large to fit through the holes, so drilling would be necessary. I am afraid this may compromise the structural integrity of the shock mount, though. Maybe I just need to send the whole deal back.
Jetfixr
• 45 posts
Posted:9/13/2006 18:34
How close are the u-bolt holes to the size of the u-bolts? Will reaming the holes slightly larger work . or drilling up to the next standard necessary? Also how far off is the alignment of the holes? More than a hole size difference and I would think you've got incorrect hardware.
Jerry
Posted:9/13/2006 18:55
I've seen several Hellwig kits that were missing hardware, and some that had a few nuts with the wrong thread pitch, but this U-bolt problem is a new one to me.
Ex2005
• Whiting, IN, USA
• Registered on 7/19/2006
Posted:10/4/2006 16:39
I found the same problem with the U bolts supplied by Hellwig. I just reused the stock Ubolts which are hardened steel and even though they are thinner seem stronger. They were plenty long. The end link bolts fit fine in the frame holes. You need to use the hole further up and back from the holes used by the cable clamp on the drivers side as they are too small and designed for the clamp assembly, not the sway bar.
Maxx_001
• Florence, SC, USA
• 9 posts
Posted:10/5/2006 13:59
Thanks!! I'm glad someone else had this problem. I haven't gotten anywhere with Hellwig's support. They said they would check with their installer, and I have not heard back in several weeks. The frame hole you mention is the right size, but I was concerned that it is too far back. I have renewed confidence now that you told me that is how yours was installed. How long has yours been instlaled?
Thanks!!
Matt
Ex2005
• Whiting, IN, USA
Posted:10/5/2006 16:38
The Hellwig has been installed for about a week, all seems fine. I also installed Billsteins at the same time. I have yet to tow with the bar installed so I do not know how much of a difference they have made.
Maxx_001
• Florence, SC, USA
• 9 posts
Posted:10/6/2006 07:23
Do you have the LANDYOT Radius Rods too?
