interior seating
Thread Statistics:     Users to Post: 5   |   Total Posts: 8   |   Total Views: 1172
superduty59
• Carmel, IN, USA
• Registered on 3/2/2006
• 19 posts
Posted:12/7/2006 19:02
I purchased a center jump seat for the front of my EX to replace the center console which I call the Ex-hole, due to the fact that it swallows many items and takes a recon mission to recover. My problem or question to you experts is how can i remove the armrests on my buckets to make the jump fit and functional? And will I need a upolsterer/surgeon to do this and make it look good?
wackmaster66
• windsor, XX, Canada
• Registered on 2/13/2006
• 24 posts
Posted:12/10/2006 12:07
what you need to do is peel the learher cover forward until you can get to a hidden bolt where the arm rest pivots from. remave the bolt and your good to go
superduty59
• Carmel, IN, USA
• 19 posts
Posted:12/10/2006 18:23
the leather cover on the armrest or the seat ?
wackmaster66
• 24 posts
Posted:12/11/2006 02:22
just pell the leather back on the arm rest,starting between the seat and the arm rest.you only have to get it about 2 or 3 inches. until you can see the bolt. i had this done on my drivers side arm rest.had it widened and legthened for a more comfortable right arm resting postion.
superduty59
• Carmel, IN, USA
• 19 posts
Posted:12/11/2006 17:59
thanks for the help!!!!
Posted:12/12/2006 02:33
However, the armrest stop is welded (if I'm not mistaken) to the seat frame. You can remove the armrests easy, it is that stop that might have to be cut off. Until then, you will not be able to raise the back of the "jump-seat".
edited 12/12/2006 02:39
rbscholes
• Tucson, AZ, USA
• Registered on 8/5/2009
Posted:8/5/2009 23:59
Where did you buy your jump seat? Aftermarket or stock? Do you know if a truck jump seat will fit the excursion?
48super6
• pittsburgh, PA, USA
• Registered on 8/30/2003
Posted:8/13/2009 08:27
I was thinking of doing the same thing to my Ex. Let us know how you make out. Mine has the cd changer in the counsel and the rear radio controls in the back- how are you dealing with those?
Whose jump seat did you use? Maybe you can post some pics.
Thanks and good luck with your project!
interior seating
