Vibration in the drivetrain at Highway speeds
Thread Statistics:     Users to Post: 4   |   Total Posts: 10   |   Total Views: 8017
02excursion73
• Herndon, VA, USA
• Registered on 1/8/2007
• 46 posts
Posted:1/23/2007 19:01
2002 Excursion 4*4, 7.3psd. I am getting a vibration, more like a deep, low humming noise in the floor between 65 and 75 mph. I can feel it in my feet. It sounds like it is coming from the center of the vehicle. I have just replaced the tires and the problem was there with the old tires. The vibration goes away at 80 mph. My local shop thought it could be the driveshaft so we sent it off to be checked. No luck. The driveshaft shop said it was in balance. There is what looks like a rubber dampener around the driveshaft near the differential. The Superduty trucks do not have this piece. Could this part be the cause? I tried putting the truck in neutral at 75 mph to take away the load on the drivetrain but the noise is still there. I also have my eye on the trans mount because I am experiencing another noise/vibration at low speeds when I am on and off the gas - sounds much like a manual transmission. Has any one experienced this problem and know how to fix??
timsexcursion
• Northeast, VT, USA
• Registered on 2/8/2004
• 27 posts
Posted:1/24/2007 20:07
I have been having this problem for the last few months and have narrowed it down somewhat. Check out these threads of mine.
http://www.supermotors.net/clubs/fordexcursions/forums/thid-6079-need-info-on-replacing-rear-end#32382
http://www.ford-trucks.com/forums/565975-need-info-on-rear-end-replacement.html
I would very much like to know if you have metal on your drain plug magnet in you rear end. I'm at the point where I'm going to have the pinion bearing replaced. I'll let you know if that fixes the problem.
Tim
2000 Ford Excursion 7.3L
Superchips 'Tow Safe'
K&N Air Filter - Stock Airbox
Tru-Cool 4490 Trans Cooler
02excursion73
• Herndon, VA, USA
• 46 posts
Posted:1/26/2007 17:40
Tim,
Thanks for the response. It sounds like we have the same problem. I just returned from a 500 mile round trip to NJ and the noise/vibration is getting much worse. It was so bad at 70 mph that I was not sure if we would make it back! I called my mechanic while I was driving and he strongly believes it is the pinion bearings since they just checked the driveshaft and installed new tires. I am taking it in on Monday and I will let you know what they find.
Brian
timsexcursion
• 27 posts
Posted:1/29/2007 14:49
I guess your going to get your pinion bearing fixed before me...let me know if it fixes it. I'd also like to know if you have metal in the rear end and if you do, are they replacing the pinion and ring gear as well. Thanks.
Tim
edited 1/30/2007 18:58
Posted:1/29/2007 17:51
I'd also like to know if you have metal in your rear end ....
Oh, this is tempting, but I will bite my lip. Or in this case, wring my hands from typing something I may regret later.
02excursion73
• Herndon, VA, USA
• 46 posts
Posted:2/1/2007 19:42
Tim,
I got the my Ex. back today from the shop. The head mechanic and owner of the shop (who owns a nice Ex. himself) did all the work. He found the Pinion bearings to be in bad shape but not terrible shape. He also found a bad, pitted wheel bearing on the passenger side during teardown. He did not notice any large amount of metal bits in the rear diff. I may have cought this in time. He also found that the parking brake cable had been hanging up on the same side. The vibration is gone at 70mph! There is still a bit of humming noise but this may be normal for a PSD Ex. drivetrain. I am still going to look at the trans mount. I forgot to have them look at this. Good luck with your rig.
Brian
02excursion73
timsexcursion
• 27 posts
Posted:2/4/2007 17:13
This is great info. Thanks for posting. I will have mine in the shop shortly and will post on my thread the results. Do you mind sharing what it cost to have your work done? Did you take your truck to Ford or a local shop? Thanks.
Tim
02excursion73
• Herndon, VA, USA
• 46 posts
Posted:2/6/2007 18:46
Tim, I use a local shop that I have a fleet account with for my business. I dont know what the cost of repairs was because they have not sent the bill. As soon as I know the total I will make another post on the site. Thanks, Brian
Posted:2/8/2007 12:50
WOW, what control!
Posted:2/8/2007 14:56
WOW, what control!
Yeah ... have heard lots of stories about gettin' the lead out ... and it wasn't about gasoline.
