Transmission Leaks
Thread Statistics:     Users to Post: 3   |   Total Posts: 4   |   Total Views: 984
up844
• The Woodlands, TX, USA
• Registered on 2/25/2003
• 8 posts
Posted:4/18/2003 21:02
I took my X in for it's first oil change on Monday. While there, the tech asked me to come down and take a look. There was a minor leak at the front of the transmission. It was leaking down the front of the trans, and flowing back to the pan drain plug. It still read full on the dipstick, while hot, so I have not taken it to Ford yet. I plan on putting it in the shop this week, to have this looked at.
My question:
Is this a recurring or problematic issue with the X?
Or
Is this a common issue between the Triton 5.4L and the 4D100 Trans?
Either way, Ford will fix this under warranty, as the truck now has 3400 miles on it.
THX
ADH
2003 Red XLT Premium
5.4 L, 2WD
Makes my 1999 Explorer look tiny.
Weatherlite
• Mountain Home AFB, ID, USA
• Registered on 10/21/2002
• 133 posts
Posted:4/21/2003 12:55
Wouldn't know if it's recurring or not but I haven't had a problem with that yet. However, I did have a leak between the tranny and the transfer case.
Good luck!
Mikie
up844
• 8 posts
Posted:5/3/2003 16:11
Ford actually stepped up to the plate, and fixed my transmission. The front seal of the torque converter was bad from the factory. The dealer replaced the seal, and flushed the transmission and cooler lines before reassembling it.
They even got me a free, yes I said free, rental truck, while mine was being repaired. I do not have the EXP warranty yet, so I did not have any rental coverage during factory warranty repairs.
It is shifting a little harder since the work, but it might just be loosening up a bit.
5.4 L, 2WD
Dave Sullivan
• Kitchener, XX, Canada
• Registered on 2/27/2003
• 199 posts
Posted:5/6/2003 14:20
Could it be that there are some good dealerships around?
Dave.
Transmission Leaks
