dddenio
Detroit Lakes, MN, USA |
Registered on 8/18/2004 |
41 posts |
Posted:6/24/2007 02:06 |
I broke mine by jacknifing enclosed trailer with rear window hatch open. You can't burn $1,100 as fast as that glass explodes. I hear most break the glass by closing lift gate and then barn door.
2001 7.3L F350 CC LB 4x4 5" Exhaust, pillar guages, BTS Trans, US Gear Underdrive, DP 6 pos chip, V10 Trans Cooler, DieselSite - Coolant Filter Kit, Evans Coolant, 203 stat, DI reg Fuel Return, GT38R BB Turbo, AFE 2 Intake, Banks Intercooler, Air Rite Bags, |
BigIronDriver
Kodiak, AK, USA |
Registered on 2/2/2005 |
6 posts |
Posted:7/8/2007 01:39 |
As I stated initially, both times, my rear window broke when the driver's door was closed. The second time, I took it to the Ford dealer and he noticed that the break appeared to have originated on the bottom of the glass, about 8 inched from the right side. The shatter patterned appeared to fan out from the very edge. The glass installer and the dealer said that there weren't any bulletins out about this, but the installer said that he didn't expect it to break a third time. So far he has been right. I'm happily going on four months without having to replace the back window. Yeah. Now I have other problems to deal with that I will cover in a different post.
Todd X
2000 PSD, XLT |
dnevins
 Subscriber since 12/29/2009 |
San Diego, CA, USA |
Registered on 12/28/2009 |
340 posts |
The detail the dealer spotted is the useful one: the break started at the bottom edge of the glass, about 8 inches in from the right side. Tempered glass is strong across its face but weak at its edges. A small chip, or a spot where the edge presses on metal, can sit there quietly until a door slam pushes a pressure pulse through the cab and the whole pane lets go at once.
So when a replacement goes in, it is worth asking the installer to check that spot: the stops and bumpers the glass closes against, the hinge and latch mounting, and whether anything touches the glass edge there. If a second pane breaks from the same corner, that points at the mounting or the hatch, not bad luck with the glass.
Dana
https://partslogic.com |
