heat/ac blower fan only works on 1st and high??
Thread Statistics:     Users to Post: 2   |   Total Posts: 3   |   Total Views: 607
4Lance
• small town, XX, USA
• Registered on 6/30/2007
• 22 posts
Posted:7/8/2007 20:00
I just bought my 2000 limited 4x4 v10 and i noticed that my blower fan only works on high. If i set it on low it seems like a small amout of air is comming out. so i think only first and last is working?? Is there a relay for this or is it the switch?? Where would i look??
Thanks i hope someone knows the quick and easy fix
aklim
• Hartford, WI, USA
• Registered on 2/20/2006
• 133 posts
Posted:7/8/2007 23:08
On my Ex, the rearmost set of switches didn't seem to work very well. On high, it might work if you pushed the switch. Well I took the housing out and discovered that someone had pushed the plug into the switch in reverse. Switched it around and it all worked.
So, I think your problem is in the switch. Perhaps someone could chime in but you might be able to order the switch from Ford or take it out and clean it.
4Lance
• 22 posts
Posted:7/10/2007 20:15
Well i found the problem, a tech said 9 out of 10 times its the resistor on the blower housing, white plug with 4 wires going into it. It was only 11$ Just wanted to give a update for anyone else with the ame problem.
