Rear pass door loose when closed??
Thread Statistics:     Users to Post: 2   |   Total Posts: 2   |   Total Views: 770
BUSTN
• ORLANDO, FL, USA
• Registered on 2/25/2004
• 34 posts
Posted:8/7/2007 17:41
Guys, when I hit a bump the rear pass door shakes and makes noise?I can push the door in from the outside.It seems as if the bushings aren't working.I've already purchased new bushings but it did not help!Any pointers or tips on fixing this?Thanks!!!!!
Posted:8/7/2007 23:38
What bushings? The rubber bumpers? There is a small one up top and a larger one down on the bottom, both on the trailer edge of the door.
You can inspect the door latching mechanism for tightness as well as the catch. Both take a TORX bit if I recall. See if that catch is bent. Otherwise I would suspect the mechanism to be out of tolerance.
