Factory remote start 2000 Ex Limited
Thread Statistics:     Users to Post: 4   |   Total Posts: 6   |   Total Views: 839
hcirrito
• Long Island, NY, USA
• Registered on 2/23/2007
• 14 posts
Posted:10/29/2007 09:38
Hi all,
My factory remote start shuts off automatically after about 10 minutes. I have lived with this, but curious as to whether or not I can change the setting. I want to make it so it just stays on, but increasing the time would help. Thanks.
Oil-Pig
• Sheboygan, WI, USA
• Registered on 11/17/2005
• 52 posts
Posted:10/29/2007 09:50
I have the same problem. If I go up to the truck and hit one of the buttons on the door it wakes up again and the remotes work again till the truck sits for a few minutes then it goes to sleep or something?? I would love to figure this out also. I have also posted this problem with limited responses. From what I can gather its my GEM or VSS. But on my truck (2002 Excursion limited 7.4) they are one in the same. The VSS is part of the GEM?? I don't know and I cannot get a straight answer from the stealership they just want me to drop her off and pay $80 plus an hour while they poke around and probably never find my problem.
I was once told (now I don't remember the details) that a wire in my door needs to be cut. I know my truck was hit in the drivers door, and it could of been replaced with a used door from a bone yard. I was told that if the door was from a truck that didn't have remote entry a wire needed to be disconnected to enable the remote locks.???? Again I don't know if this is a valid statement. But it seems that the remote entry system goes into a "sleep" mode. I would love to have this work so I can move on to my next project-----Installing my remote starter. It doesn't pay to try to install untill I fix the problem.
I'd rather be in the boat with a drink on the rocks then in the drink with the boat on the rocks.... But either way theres gonna be a good story!!!
Posted:10/29/2007 15:01
The VSS or Vehicle Speed Sensor is located on top of the rear diff. I can see how the remote start controller would use that input as you cannot drive away without the key in the ignition when the remote-start has been activated.
As to increasing the time limit, I know my remote start would allow for longer run times but I cannot remember how I adjusted it. It is a function of the remote start system and nothing to do with the actual truck or its stock controls.
I think the "factory" remote start is an dealer add-on anyway. I don't believe it came from the factory with it, did it??
Oil-Pig
• 52 posts
Posted:10/29/2007 15:18
Sorry Should of said VSM or Vehicle Security Module
Bandit
• Austin, TX, USA
• Registered on 8/10/2005
• 38 posts
Posted:10/30/2007 18:46
Mine is set to 15 min... the max.
I'm not sure which model you have, but if you have one of the PowerCode (Code Alarm - Frod Branded) ones, this link will take you to all the install / programming pages of the manuals:
http://www.gemsen.com/ford/
Kevin
hcirrito
• 14 posts
Posted:10/31/2007 12:10
Thanks Bandit. That is the one I have. Mine is set for 10 min. At least I can increase it to 15.
