v10 2000 Trans noise??
Thread Statistics:     Users to Post: 3   |   Total Posts: 4   |   Total Views: 647
4Lance
• small town, XX, USA
• Registered on 6/30/2007
• 22 posts
Posted:1/20/2008 17:49
i have a 2000 ltd 4wd EX with 109k on it. recently i've been hearing a high pitched noise kinda like a squeeling. sitting in park idling is pretty loud and when you give it more gas it gets louder. does it right from start up i put it in gear and it goes away a little. got underneath and it sounds like towards the front of the trans front of the pan kinda. Noticed it after a long 1hr 1/2 drive on the intersate. Cheanged the fluid/filter a couple months ago and used the new black bottle trans fluid ford says to use. Mercon / Mercon V also meets mercron 3 i think it says.
My trans about ot go out? The shifts feel great. no slipping so i dunno??
davecarpe
• Newton, NJ, USA
• Registered on 9/2/2007
• 29 posts
Posted:1/20/2008 18:36
Are you sure it's not a belt? The sound you describe sounds more like a worn belt on the engine than a transmission problem.
4Lance
• 22 posts
Posted:1/20/2008 20:53
it does sound like a belt sound. but i just replaced the factory belt with a gatorback belt about 4 months ago. and i got right under the trans and i can hear it at the trans. between the tq converter and the front of the pan kinda. ????
Lance19555
• Indianapolis, IN, USA
• Registered on 8/2/2005
• 21 posts
Posted:1/20/2008 21:34
I would check the following.
1. Transfer case fluid level.
2. When you changed the internal transmission filter, you may have left the old O ring in there.
3. Power steering pump is low on fluid or the fuild is just cooked. If its jet black and stinks it cooked.
4 Or possile a bad belt tensioner.
Thats where I would start.
