Turn Signal & Airbag
Thread Statistics:     Users to Post: 4   |   Total Posts: 4   |   Total Views: 1007
speckfisher
• Missouri City, TX, USA
• Registered on 2/2/2007
• 15 posts
Posted:2/16/2008 22:55
How do you replace the turn signal switch with the air bags in the steering wheel? How do the airbags come out of the steering wheel ? Any help
2000 Excursion
7.3L 4x4
Posted:2/17/2008 11:00
You'll have to unscrew & remove the tilt wheel lever,then remove the steering wheel column plastics(2) and I believe there is either two or three screws that go up from the bottom side of the column plastic cover.
Once the column covers are off you should be able to unscrew and remove the switch assembly,I'll look for some photos.
edited 2/17/2008 11:00
Posted:2/19/2008 18:51
I cannot stress this enough ... PULL THE FUSE for the airbags. If you cannot determine which is the correct fuse, disconnect the battery(ies)!!!
You do not want an airbag to deploy while you're handling it. An airbag can deploy with enough force to break an arm ... or worse.
shiepo
• carson, CA, USA
• Registered on 6/23/2011
• 75 posts
Posted:7/10/2012 19:02
hi there i was thinking on how to replace the Switch Assembly on my car? any one know how? thanks for nay response.
