no headlights!!
Thread Statistics:     Users to Post: 3   |   Total Posts: 4   |   Total Views: 935
GasGuzzler
• Milwaukee, WI, USA
• Registered on 6/1/2004
Posted:5/5/2008 20:29
my '00 limited doesn't have auto lights, one day the headlights don't come on and the brights indicator stays on the dash. No low or high beams. All other lights work. I had the switch checked last year for the recall but it's ok. Also the 30a and both 10a fuses under the hood are fine. Has anyone had this problem.
Texas4x4
• Tyler, TX, USA
• Registered on 7/25/2003
• 289 posts
Posted:5/6/2008 08:11
Buy a cheap bulb and try it. That should at least eliminate that as a possibility.
Kevin Curry
[email protected]
http://www.texas4x4.com
Posted:5/7/2008 03:22
I would suspect the multi-function switch is bad (the turn signal stalk) OR there's a wiring problem in the steering column. Either way sounds like you're gonna need a test light and/or multimeter.
Please let us know how what the fix is!
GasGuzzler
Posted:6/10/2008 22:40
Sorry it took me so long to follow up. The problem was corrosion at both connectors where the bulbs plug in. I bought new bulbs then found the contacts were very corroded. I cleaned the connectors and now the lights work. I ended up using the new bulbs, they're noticeably brighter than the old ones.
no headlights!!
