Transmission fluid
Thread Statistics:     Users to Post: 2   |   Total Posts: 2   |   Total Views: 1393
nhoj
• Hanover, PA, USA
• Registered on 1/9/2006
• 37 posts
Posted:6/23/2008 07:02
I notice in the repair manual that the automatic transmission requires Mercon, not Mercon V or Mercon/Mercon V. There is even a caution note stating this. In preparing for a transmission fluid and filter change, I find out that Mercon is no longer made and that Fords service bulitin ows says Mercon V is OK to use. What's with the contradiction? It's OK just because Mercon is no longer manufactured??
Any thoughts?
01' Excursion V10 4X4
Posted:6/24/2008 17:47
MERCON V was reformulated to work in transmissions that required MERCON. You're fine although I still wouldn't mix the two. If you change to V then make sure you drain the tranny sufficiently.
Transmission fluid
