PCM Problem
Thread Statistics:     Users to Post: 2   |   Total Posts: 3   |   Total Views: 629
speckfisher
• Missouri City, TX, USA
• Registered on 2/2/2007
• 15 posts
Posted:8/2/2008 14:41
Was told my PCM needed to be replaced. Went to Ford to purchase to a new one a take the old one in for core. I asked the counter person if I had to do anything special to new one. He said no just plug it in.
I did that and it would only crank with the theft light on. I called another Ford because the one I bought it from was closed. I was told that I have to have the old one in the vehicle and have all of the data saved and then download the data into the new PCM after it is installed before it will start.
Does anyone know if there is anyway around this If I can't get the old one back.
aklim
• Hartford, WI, USA
• Registered on 2/20/2006
• 133 posts
Posted:8/2/2008 15:12
No way. That PCM fits multiple vehicles. You NEED to have it reflashed and at the dealership. Now, if you want to get someone to flash it for you, it would have to be aftermarket. Talk to www.dp-tuner.com
speckfisher
• 15 posts
Posted:8/2/2008 17:17
Thanks. Can it be reflashed outside of the vehicle?
edited 8/2/2008 17:18
PCM Problem
