4x4 Won't disengage
Thread Statistics:     Users to Post: 3   |   Total Posts: 4   |   Total Views: 733
RayRay1
• Piscataway, NJ, USA
• Registered on 4/24/2005
• 54 posts
Posted:12/24/2008 09:15
Very rarely use 4x4 low but used it last evening to get the rig in the driveway (backing up)... Worked like a champ but now she is stuck in 4x4 low.... What should I be looking for to fix this issue?
Oh yeah, the truck has 124,000 on the clock
edited 12/24/2008 09:22
RussellExcursion
• Los Angeles, CA, USA
• Registered on 4/4/2005
• 33 posts
Posted:12/24/2008 10:05
Call a ford dealer and ask them what they think the problem is. They've seen it all.
aklim
• Hartford, WI, USA
• Registered on 2/20/2006
• 133 posts
Posted:12/24/2008 11:56
I think the problem is you need to put the gear in neutral, hit the brake pedal and switch out of 4WD Low. Try that and let us know.
RayRay1
• 54 posts
Posted:12/26/2008 10:09
I thank you both for helping out the mentally challenged one Contacted the dealer and the service dept. told me about the neutral fix
4x4 Won't disengage
