interior lights stay on
Thread Statistics:     Users to Post: 3   |   Total Posts: 4   |   Total Views: 788
Sukhi Kainth
• Surrey, XX, Canada
• Registered on 5/24/2004
Posted:3/7/2009 14:45
My dome and door lights stay on, i believe it could be the door ajar switch for the rear hatch because i have the am power steps and if it was the side doors the steps would stay open. My question is, where is the rear door ajar switch? Or anyone else had a similar problem? the lights go off after i start driving and go over 30.
HBJJAM
• Minneapolis, MN, USA
• Registered on 6/23/2005
• 93 posts
Posted:3/7/2009 17:18
I believe it is in the multi pin switch on the pillar.
A little emery cloth on the end of each pin and the contact plate should clean it right up.
Make sure the pins are not stuck 'in'
As well as making sure the barn doors are fully shut as well.
I have had this happen about three years ago, cleaned it as described and no issues since.
Good thing about the dome light though, since it is on a time delay it shuts off and will not kill your battery
Posted:3/8/2009 08:43
The rear barn doors have no sensors or anything electrical attached to them nor activated by them. There are no contact switches in the door jambs. The liftgate has two door-jar switches ... one on each side. Of all the door-ajar switches on the X, these are the easiest to access. Unscew the interior pull-handle, then simply pry the bottom interior trim panel off the liftgate.
I replaced the older style door-ajar switches on my '01 with newer ones, but many folks have had success with doing nothing more than spraying/flooding the switches with WD40. I haven't had this problem with my '05.
edited 3/12/2009 16:31
Sukhi Kainth
Posted:3/12/2009 11:30
fount them, sprayed some lube on them, now they holding up good so far.
thank you
