Front Wheels Binding when switched to 4wd
Thread Statistics:     Users to Post: 3   |   Total Posts: 3   |   Total Views: 820
topls68
• maywood, IL, USA
• Registered on 2/8/2009
• 18 posts
Posted:12/20/2009 16:22
2001 Ford Excursion limited with 4wd. I haven't had to use 4wd drive on this truck in at least a year. I got out turned the hubs to lock, then switched to 4wd on the dash. 4 wd engaged and I was off and driving. But when I turn corners, normal right or left hand turn I'm experiencing binding at the front wheels. I don't remember them binding previously. Could this be a hub or ujoint issue? any ideas would be appreciated. Thanks in advance!
Andy Anderson
• Jacksonville, FL, USA
• Registered on 1/17/2005
• 77 posts
Posted:12/25/2009 16:06
Make sure you are on loose ground when using the 4x4, elementary I know, but just making sure. It is probably the main hub assembly bearings though.
ManVanTank
• Greenville, NC, USA
• Registered on 6/8/2009
Posted:12/29/2009 13:22
Question. I too have an 01 limited 4X4, and my auto and manual indicators have worn completely off. In reference to the dot on the hubs; which way do you turn to put the hubs in "auto" on your Excursion?
