Clunk/Pulling sound underneath drivers side?
Thread Statistics:     Users to Post: 28   |   Total Posts: 35   |   Total Views: 5421
You must be logged in to post in or subscribe to this thread.Pages: 1 2 3 4
PHILLYX
• Philly, PA, USA
• Registered on 6/11/2003
• 9 posts
Posted:6/11/2003 21:49
Need Help....When coming to a stop there is a clunk or something pulling underneath the driver side (my left foot to be exact!)..00' v10 4x4 LTD...any suggestions? I looked underneath myself..pulled and pushed on leafs, bushings, u-joints, etc...Having a tough time here
Lou Beckler
• Wakeman, OH, USA
• Registered on 4/27/2003
• 43 posts
Posted:6/12/2003 03:10
Check your body mounts on that side.
PHILLYX
• Philly, PA, USA
• 9 posts
Posted:6/21/2003 15:41
MY CLUNK JUST WONT GO AWAY ANY MORE SUGGESTIONS....IT ONLY HAPPENS WHEN COMING TO A STOP.......
birdman127
• baltimore, MD, USA
• Registered on 10/13/2002
• 581 posts
Posted:6/21/2003 20:50
How about greasing the slip yoke on the 2 drive shafts
Moderator
2000 ltd 6.8 V10*4.30LS*
Lots of mods
check my gallery
MrRottnDog
• New Lenox, IL, USA
• Registered on 2/19/2002
• 103 posts
Posted:6/22/2003 01:50
You might want to check the track bar mounting brackets. I've heard of them coming lose and causing similar symtoms!
MrRottnDog
birdman127
• 581 posts
Posted:6/22/2003 07:38
Also check the front sway bars bolts as they tend to get loose after a while! Grab a socket and give them (all nuts) a good twist.
Moderator
Lots of mods
check my gallery
trauski
• indianapolis, IN, USA
• Registered on 3/10/2003
• 44 posts
Posted:6/23/2003 08:26
try jacking car up and when the leafs are seperated from no weight put grease inbetween them. ford dealer said this happens to the big trucks some with the springs seizing up.
dnp
• Jackson, MS, USA
• Registered on 1/20/2003
• 37 posts
Posted:6/24/2003 14:53
I have some clunking going on myself (2000 V-10 4x4), so can anyone tell me the process through which one can tighten the body mounts? I may be a complete dumba**, but when I looked at them, I couldn't figure out how to tighten them......
Thanks for any help,
dnp
Pharmer
• Mackinaw City, MI, USA
• Registered on 12/19/2002
• 52 posts
Posted:6/25/2003 14:13
Philly,
Does not sound like cab mounts. DNP check old thread about cab mounts. Philly, did you check sway bar? How about brake calipers, spring mounts, somethings moving. The drive shafts have to removed to grease??? properly.
http://www.superford.org/registry/vehicles/index.php?vID=2305&profile=1
edited 6/25/2003 20:51
wdp34
• Alta Loma, CA, USA
• Registered on 5/25/2003
• 12 posts
Posted:7/10/2003 16:24
I am having the same clunking sound. I took my X in on tuesday night to have a thorough once over by the Ford Techs, had it about 2 months now, and they still have it. They took care of the few little squeeks and rattles I heard, and then on to the clunking sound. It always happens for me after you drive it awhile. They have been test driving it since yesterday and it hasn't done it for them. I am waiting for the return call now. From what was posted here and on other sites and edmunds, this clunking thing sounds like it is an anomily(spell ck) with excursions. I will let you know what they tell me.
Darren
