Home/ Forums/ Car and Truck Make and Model Specific/ Crown Victoria, Marauder, Marquis/ Differential Question
4 posts 3 contributors 1,416 views
DO
Douglink92OP
  • Member since Feb 2016
  • Sacramento, CA, USA
Feb 18, 2016 at 6:46 PM
How do i figure out the Gear ratio on my 2005 CVPI?
DB
dbmcd
Feb 18, 2016 at 8:47 PM
Look at the label inside the driver's door. It will list the axle code which will probably read Z5, which is 3.55:1. Or lift the rear end of the car and mark the tires and driveshaft. Rotate and count how many times the driveshaft turns relative to the tires.
HO
hondaclf
Feb 19, 2016 at 1:48 PM
Z5 is open 3.27 and the most common gear ratio so you were partially right.
The door sticker will have a 2 part axle code, you can decode it here.
Door sticker decoder
DB
dbmcd
Feb 19, 2016 at 4:21 PM
My '05 Shop Manual says 1is 2.73, 4 is 2.73, 5 is 3.55 and C is 3.27. I tried to insert photo of page but no luck. I seem to recall this conversation before.
