Home/ Forums/ Car and Truck Make and Model Specific/ Crown Victoria, Marauder, Marquis/ Misfire #3 cyl. Help needed
3 posts 2 contributors 1,734 views
GP
GPP2004CVOP
  • Member since May 2010
  • Sterling Heights, MI, USA
May 2, 2017 at 9:39 PM
Hi Everyone,
I had a new one hit me today. Car was running fine, then at a stop light the car started running rough check engine light came on and it sounded like a tractor. I pulled into a parking lot and hooked up m code reader and came back with a P0303 code. I checked the area round the #3 coil pack and found what looked like a spring comming out from under the coil pack. I am assuming the boot must have had a hole and shorted out against the head. Replacing the boot and plug is easy enough. But what would cause it to sound like a tractor putting along? Could it be a plug blown out of the head? I have heard of this on the Triton truck motors. Is this also a issue on Crown Vic PI?
If you click on the first photo it with link you to a video. So you can hear the sound it is making. The second photo shows the spring.
Thanks for your time and any help.
Erik
P0303 misfire 4.6l Crown Vic by E Crawley, on Flickr
Blown out coil boot 2004 Crown Vic 4.6l by E Crawley, on Flickr
CU
curemode2002
May 3, 2017 at 8:31 AM
A plug blowing out would not be unheard of with these motors. Also though the '99 and on cars had a limp mode built in to keep them from damaging the motor. I have not had mine go in to limp mode so I am not sure what it sounds like, but it does limit your maximum speed, etc.... Also a plug blowing out of the head could do what you show in the pic of your coil as well.
GP
GPP2004CVOP
May 4, 2017 at 1:39 AM
Update to my problem.
FYI It was a blown out plug. I had the problem comfirmed by a Ford service tech. I got lucky the coil boot shorted and blew up and the plug unscrewed itself and did not damaged the threads. So a new coil boot and spark plug and $12.25 later. The Vic is back up and running good as new.
Erik
