Home/ Forums/ Car and Truck Make and Model Specific/ Crown Victoria, Marauder, Marquis/ 03 Ford Crown Vic
03 Ford Crown Vic
3 posts 3 contributors 2,552 views
AT
AteamOP
Nov 30, 2017 at 5:44 PM
I Have an 03 ford crown vic. I let some people drive it and work on it. So the car started when I came to pick it up. It had a bad hesitation and the wire harness for the lighting and engine was completely damage. I replace bother harness. Lighting works perfectly. Engine harness does not give power to when ignition is turn on to injectors or coils. All fuse and relays are Good. I test power and ground habe both with engine off. When key is on ground but know power to fire the car. It does crank but won\\'t start and run. Any thoughts????
PJ
PJC1
  • Member since Aug 2017
  • 7 posts
  • Nottingham, PA, USA
Dec 1, 2017 at 8:04 AM
Check the connection at the PCM
2002 MGM LSE 103k
1998 Ddoge Dakota 4x4 163k
NV
Nola_Vics
  • Member since May 2018
  • metairie, LA, USA
May 5, 2018 at 2:05 AM
check connecrions and relays for your starter
