Home/ Forums/ Car and Truck Make and Model Specific/ Bronco, Bronco II/ Wiring
Bronco, Bronco II
Wiring
2 posts 2 contributors 3,357 views
JC
jcistazOP
Jan 10, 2026 at 2:35 PM
Hello, I just bought my dream Bronco, 1988 Bronco. I have a question around two black leads from the battery negative to a small connector near the radiator...cannot see where it goes form there. Are both leads ground? Looks like one is loose
edited Jan 10, 2026 at 2:46 PM
DN
dnevins
Oct 22, 2026 at 8:42 PM
Sorry this went so long without an answer. From your photo, that two-wire plug with the crimped yellow and red butt splices is not factory. It looks like a battery charger or tender lead, or a feed someone added for an accessory. The factory negative cable runs to the engine block, with a smaller pigtail to the body.
Check it with a meter, key off: if one pin reads ground and the other reads battery voltage, it's a charger lead. Put a fuse in the power side or remove it. There's a bare, frayed wire end in the photo too, and a loose one like that can short against something.
Dana
