SuperFord.org Forums
Crown Vic Exhaust????
Thread Statistics:     Users to Post: 8   |   Total Posts: 15   |   Total Views: 3710
Aaron Lara
• Las Cruces, NM, USA
• Registered on 8/20/2003
• 20 posts
Posted:8/20/2003 23:53
Where can I find some good aftermarket exhuasts for my 98 PI? thnx in advance
Aaron Lara
• 20 posts
Posted:8/21/2003 00:16
also where can i find a cold air intake for it?
Embassy Vic
• Where East meets West, KY, USA
• Registered on 2/4/2002
• 72 posts
• 4
Posted:8/21/2003 00:51
Aaron,
The only full aftermarket exhaust for the Crown Vic that I can recall is produced by Borla.
However, why do you want a new exhaust? The exhaust on your '98 P71 is stainless steel and will last just about forever.
If you are just wanting a meaner sound, consider some Flowmasters, Dynomaxes, or other performance mufflers. You might also want to remove the rear resonators.
From a performance standpoint, the exhaust is not a restriction on the Vic/Grand Marquis. The restriction are the heads and headers.
Since you also have a '98, I would swap your heads for a set of ported and polished Ford Performance Improved heads. These heads come standard on the '01 and up Crown Vics and Grand Marquis. I believe Mustangs have had these heads since '98.
Right now, I am not aware of any performance headers for our cars. Most guys that have them have modified 4.6L Mustang headers for their application.
As for an air box, I would recommend getting the Marauder airbox and MAF. There is an article here on Superford about this. Once you change the MAF, you will need a custom chip and possibly colder plugs. Many members at www.crownvic.net and www.crownvic.us have purchased these parts along with a custom chip at:
http://www.reinhartautomotive.com/index2.ivnu
For around $500, this is the best bang for buck modification package you can do to your Vic.
If you look at the air box, you can see that there is no way to get cold air into the engine.
Some people have cut the snorkle off the stock air box and have ran a tube down under the front fender. Be careful not to get water in there.
Another alternative site for a different, possibly better intank is:
http://www.angryducktofuracing.com
Finally, if you want to go all out, check out Allen Engineering Developement. They have a bolt-on supercharger for our cars. However, I would be the ported and polished PI heads first.
Good luck.
1998 Ford Police Interceptor
www.crownvic.net
www.crownvic.us
http://www.midwestvics.org/
edited 8/21/2003 00:55
Aaron Lara
• 20 posts
Posted:8/21/2003 17:07
Thanx man! big help! I wasnt looking for the whole exhaust package i just want a meaner sound out of it. Where can i find some flowmasters? I was also condiering a Diablo sport chip do u know if these are any good? One last question, wouldnt the air be cooler if i got an aluminum intake as opposed to the stock rubber one? sorry for all the questions im new at this and Thanks!
Aaron Lara
• 20 posts
Posted:8/22/2003 19:28
Does anyone know the dimensions on a stock muffler? length, width, height, inlet and out let size, any responses will be greatly appreciated.
Embassy Vic
• 72 posts
• 4
Posted:8/26/2003 01:56
Check out www.summitracing.com for a set of Flowmasters. They are certainly loud. Dynomax also makes a nice muffler that is just loud enough. You can also have the rear resonators removed.
Diablo chips were popular for a little while but I would spend the extra and have custom chip burned for your specific needs, gearing, perfomance mods, etc.
Check out:
or
www.fordchip.com
An aluminum intake would heat up after a while from being so close to the engine.
Really, cold air is not or air flow to the inake it not the major restriction on our cars. It is the heads and the headers.
I would get the Marauder airbox and MAF for increased airflow or check out:
Their intakes are aluminum, I believe.
The stock exhaust is around 2 1/2 or 2 1/4 inches. I would do some searching on
www.crownvic.net in the 4.6L forum and 4.6L archives for more specific measurements.
Again, good luck.
www.crownvic.net
www.crownvic.us
edited 8/26/2003 02:01
Mark Ray
• charlotte, NC, USA
• Registered on 8/26/2003
Posted:8/26/2003 19:03
Aaron Lara,
We are the industry leaders in Panther Performance Parts. We have several Police Vics
Running our Vortech systems. We are competitively priced with allot of the other tuners,
and offer more power and better eta's at the track. Please see our site for more
Details. www.zeusautomotive.com We can help you out with all your crown vic needs.
704-393-8784
Mark Ray.
Embassy Vic
• 72 posts
• 4
Posted:8/31/2003 16:48
Aaron,
Until you do really tear into your Vic, you can do the cheap, gutted air-box mod.
http://www.crownvic.net/ubbthreads/showflat.php?Cat=&Board=UBB23&Number=354002&page=0&view=collapsed&sb=5&o=365&fpart=1
All you need is a dremel tool and a little patience.
www.crownvic.net
www.crownvic.us
Aaron Lara
• 20 posts
Posted:8/31/2003 20:37
well i took the horn/cone looking thing off and i was reading about removing that plate but is it worth it? does it really make a difference? also can you tell me where the Evap emission control system vent control valve circuit is? my vic has a p1451 code and is burning more gas than it normally does. thnx~
Sipowicz
• Burnsville, MN, USA
• Registered on 8/30/2003
Posted:9/5/2003 07:42
Are the aforementioned Mustang headers modified at all? I have a source locally which may be able to provide shorties for my 94 GM LS.
