SuperFord.org Forums
Crown Vic K&N???
Thread Statistics:     Users to Post: 7   |   Total Posts: 7   |   Total Views: 1793
Aaron Lara
• Las Cruces, NM, USA
• Registered on 8/20/2003
• 20 posts
Posted:10/5/2003 21:14
Does anyone have a K&N airfilter on their Vic? can you feel a difference? I want to get one but want to know if its actually worth the $50. Thanx in advance
Embassy Vic
• Where East meets West, KY, USA
• Registered on 2/4/2002
• 72 posts
• 4
Posted:11/7/2003 15:01
Many Crown Vic/Grand Marquis owners have had engine problems due to the oil on K&N filters covering the MAF sensor and the throttle body.
One of the more technically savy members on CVN dynoed his car with his OEM Motorcraft filter and then the K&N. The dyno actually showed a loss with the K&N.
Verdict:
Save you cash. Stick with stock filters (change them regulary) and gut your airbox (free mod) instead for a little more response.
1998 Ford Police Interceptor
www.crownvic.net
www.crownvic.us
http://www.midwestvics.org/
kirk baker
• arlington, VA, USA
• Registered on 10/31/2002
Posted:11/25/2003 14:49
ive got 2002 grand marq. and have the k&n filter in mine.cant say about the perf.end the garr. with the k n is good and you can call and ask about the other statement of oil on the sensor.saving some money withk n because of the life length of k n.50,000 miles then clean and reoil k n vs 5 to 6 dollars every 6000 mile change for motorcraft.just a thought
edited 11/25/2003 14:51
kidder1
• Attleboro, MA, USA
• Registered on 3/21/2004
• 18 posts
Posted:6/2/2004 15:35
I HAVE A 89 CROWN VIC W/A K&N FILTER,THERE IS A DIFFERENCE.I RECOMMEND IT.
Michael Carson
• New Salisbury, IN, USA
• Registered on 11/11/2003
Posted:7/14/2004 20:29
The trick to the K&N is to not over oil the filter, I have known of several people having problems but it was because of them putting so much oil on the filter it is dripping off of it. Follow the directions on the box and it should work just fine. There is a little difference, but you can't tell much since the stock airbox is so restrictive, try cutting some holes.
Devon Corrias
• Virginia Beach, VA, USA
• Registered on 7/26/2004
Posted:7/27/2004 08:58
You should check out ADTR.net they have all sorts of stuff for the crown victoria. The thing you want to do is get a conical air filter not the stock paper stuff or even k&n squares. If I were you i would save up a little more money then get a Fuel Injection Performance Kit (FIPK) Air Intake for $265.00. Just advice before you do anything check out [url]ADTR.net good luck , Devon Corrias
Devon Corrias
Jim Hall
• New Albany, IN, USA
• Registered on 3/20/2004
Posted:8/24/2004 20:15
Put one on my 2003 Ranger no change in profromace. Going to put old one back one.
Crown Vic K&N???
