Just did the math, and.......
Thread Statistics:     Users to Post: 3   |   Total Posts: 5   |   Total Views: 669
Wheels
• Visalia, CA, USA
• Registered on 1/20/2003
• 214 posts
Posted:11/13/2003 17:46
Figured out that our Ex has 3.08 gears!!! Is that right??? Could it be???
birdman127
• baltimore, MD, USA
• Registered on 10/13/2002
• 581 posts
Posted:11/13/2003 18:07
NO You do have a couple of options though.....5.4--4.10....6.8--3.73...or...4.30...7.3 or 6.0 diesel--only 3.73
now if you have oversized tires then you have reduced the gear ratio to a smaller gear. hope this helps.
Moderator
2000 ltd 6.8 V10*4.30LS*
Lots of mods
check my gallery
edited 11/13/2003 18:08
Wheels
• Visalia, CA, USA
• 214 posts
Posted:11/14/2003 17:05
So does this mean with a V-10, the only possibilities could be 3.73 or 4.30???? If so I feel better...
Posted:11/15/2003 19:29
How exactly did you come up with that?
Wheels
• Visalia, CA, USA
• 214 posts
Posted:11/15/2003 22:20
I figured out where I screwed up, I used the RPM's in overdrive instead of the RPM's in Drive, the formula requires the RPM's from the 1:1 gear. The formula I used was in 4x4 Garage magazine...it is...(RPM x tire diameter) divided by (MPH x 336)
