Tire size and brand/model
Thread Statistics:     Users to Post: 13   |   Total Posts: 17   |   Total Views: 2963
SRO2000X
• Dallas, TX, USA
• Registered on 11/16/2003
• 35 posts
Posted:11/17/2003 20:02
Hi all,
Im thinking of going to a taller tire to fill out the wheel wells.
I have the stock 265/75R16s now.
Will this increase milage?
Will it harm handling by making the truck more mushy?
And can you recalibrate the speedometer for the new size?
I need an AT or even a mud tire with very good pucture resistance.
I have the Wangler MT/Rs now.
They're very tough but they slip on my rims so I'm looking for something else.
Any BFG AT KM users out there?
They seem to be similar to the MT/Rs but maybe they wont slip on my rims.
SRO2000X
I love my truck!
Posted:11/17/2003 21:56
I had a set of 285 BFG TKO's installed a few months back which seemed to fill the front fenders
RS-TX
• Little River, TX, USA
• Registered on 11/22/2002
• 298 posts
Posted:11/18/2003 12:56
If you get taller tires, but NOT wider tires, and drive a lot of highway miles, then it is, theoretically, possible to get better mileage. The catch is that a 285/75/16, for example, is taller, but also wider, therefore increasing rolling resistance and decreasing mileage. I did not notice any mileage difference when I got my 285 tires.
If you pull a trailer a lot or carry very heavy loads, the slightly softer sidewall may make a difference. It will be difficult to tell in all probability.
Yes, so I've heard. My 285 tires don't seem to have changed my speedo much. If anything, I am now closer to the actual mileage.
I like my Coopers. They do make a more aggressive tire. See www.coopertires.com for more options. Good luck.
Rick
2004 VW Jetta TDI
SRO2000X
• Dallas, TX, USA
• 35 posts
Posted:11/18/2003 18:03
Hi all,
Thanks for the great replies.
I will check out the Coopers!
SRO2000X
I love my truck!
SRO2000X
• Dallas, TX, USA
• 35 posts
Posted:11/19/2003 13:09
Hi CHPMustang,
Did you change rims?
The 285 need a 7.5 in min rim width.
I think my stock Ford rims are 7.0 in.
I havent found a larger tire that would work on 7.0 in rims.
Is this right or am I off on the rim size?
SRO2000X
I love my truck!
MONGO
• Sandwich, IL, USA
• Registered on 1/3/2003
• 210 posts
Posted:11/19/2003 20:47
You will have no problem runnig 285`s on your stock rims. Just put a set NITTO`S 285-75-16`s on 6" chevy, notice......small print, with no problems. Check out NITTO`s, you might really like them. Better tread pattern, less noise, better ride, and about $30 or more cheaper.
SRO2000X
• Dallas, TX, USA
• 35 posts
Posted:11/28/2003 23:19
Hi All,
Goodyear just payed about 2/3rds of the cost to replace my 265/75R16 MT/Rs with a new set of 285/75R16s MT/Rs.
They fit perfect and ride very nice. I now remember just how quiet these tires can be when they're in balance and not worn out.
I really dont think they're any louder than my old Steeltex ATs.
The look MUCH better than the stock size too!
Time will tell if they're going to slip.
SRO2000X
I love my truck!
edited 11/29/2003 00:14
cwbyinjeep
• Registered on 8/5/2003
• 47 posts
Posted:12/1/2003 16:49
I have BFG 305/75R16 A/T's on my stock ford rims (4x4 7.3L PSD) and have had great results on and off road and while towing. I had to have them trued around 20k into them, but have well over 40k on them now and more to go. I do not get any rubbing on floor boards or fendwells and overall ride comfort has improved IMHO. The tallest tire you can recalibrate the speedo to is the 305 I believe which about equal to a 33" tire if it were on an 8 inch rim. Will probably replace with the same tire whenever these things wear out.
Bobby Wooldridge
BMW Motorcycles of Atlanta
spartan
• Nashville, TN, USA
• Registered on 7/17/2003
• 87 posts
Posted:12/2/2003 11:40
Without a lift I would go with the 285's. Tires I can personally recommend: BFG AT KO, Michelin LTX if you do mostly highway and Bidgestone AT REVO's - not the standard AT's. Recently put a set of these on a 1997 Lancruiser and they are incredible. I have heard great things about Nitto's, but have no first hand experience with them.
cwbyinjeep
• 47 posts
Posted:12/3/2003 13:50
Without a lift?????? why? if you run 305's on stock rims they will equate to a 32" or so tire and not rub on a 4x4 PSD X with no lift. I have not ran into any really odd tire wear either because of the 305 being on a stock width rim.
Bobby Wooldridge
