Door lock not working
Thread Statistics:     Users to Post: 2   |   Total Posts: 2   |   Total Views: 653
Coach3rd !!
• Chesapeake, VA, USA
• Registered on 1/21/2003
• 43 posts
Posted:3/29/2004 13:04
Time for things to fall apart!! My 2000 ex passenger side rear door lock will not work when you try and unlock/lock the doors. You have to use it manually. Anyone know the cost of replacing the unit that makes this work? Thanks, Coach
• 0 posts
Posted:3/29/2004 14:49
bout 50 bucks from ford.
If yours in under warranty they should be free.
Take off door panel, remove the sticky plastic sheet. The actuator is right at the latch in the door,
you will most likely have to remove the outer handle that has 2 bolts holding it on, to manuever it off the linkage.
good luck.
