Anyone have an Excursion Repair Manual?
Thread Statistics:     Users to Post: 2   |   Total Posts: 2   |   Total Views: 433
romulin
• Smyrna, GA, USA
• Registered on 8/27/2003
• 28 posts
Posted:6/9/2004 06:52
Does anyone have an Excursion repair manual? I need to know the foot pounds to torque the driveshaft bolts that attach the driveshaft to the rear end and the transfer case.
Thanks....Brian
2003 Excursion 4x4, V10
Dave Sullivan
• Kitchener, XX, Canada
• Registered on 2/27/2003
• 199 posts
Posted:6/12/2004 23:25
OK Here goes.
The axle end of the driveshaft is 35Nm (26 lb/ft)
The transfercase end of the dirve shaft is 102Nm (76 lb/ft)
If you have a two piece rear axle, the center bearing support is 63Nm (47 lb/ft).
WARNING: Replace with new bolts and retainers after the third removal.
Dave S.
