Bulletins for 2000 Ford Truck Excursion 7.3L DSL
Thread Statistics:     Users to Post: 3   |   Total Posts: 3   |   Total Views: 2731
Don Murray
• Bridgewater, NJ, USA
• Registered on 1/5/2004
• 132 posts
Posted:6/28/2004 21:02
Bulletins for 2000 Ford Truck Excursion 4WD V8-445 7.3L DSL Turbo VIN F
Safety Recalls
TSB Number Issue Date TSB Title 01S24 AUG 01 Recall - Defective Wiper Motor Switch/Gear Cover
01S09 MAR 01 Recall - Headlamp Switch Knob Replacement
General Recalls
TSB Number Issue Date TSB Title 99B19 AUG 99 Campaign - Headlamp Switch Replacement
Service Bulletins
TSB Number Issue Date TSB Title 03-15-1 AUG 03 Rear Window Defroster - Inoperative
03-14-8 JUL 03 A/T - Cooler Flushing Service Tips
03-14-9 JUL 03 Diesel Engine - Loss of Power/Turbocharger Oil Leaks
03-14-10 JUL 03 Diesel Engine - Turbocharger Pedestal Oil Leaks
03-14-3 JUL 03 Drivetrain - 4X4 Hub Non-Engagement/Disengagement
03-11-2 JUN 03 Drivetrain - Hub/Bearing Rocking End-Play Measurement
03-11-6 JUN 03 Electrical - Wiring Soldering/Crimping Tips
03-4-1 MAR 03 Drivetrain - Front Locking Hub Service Tips
02-21-1 OCT 02 A/T - Torque Converter Access Plug Dislodges
02-21-13 OCT 02 Engine - Cylinder Head Straightedge Surface Check
02-21-9 OCT 02 Lighting - Additional Turn Signal/Hazard Flasher Bulbs
02-20-8 OCT 02 A/C System - Diagnosis and Service Tips
02-20-4 OCT 02 Diesel Engine - Oil Leak Diagnosis
02-20-5 OCT 02 Diesel Engine - Oil Pan Corrosion
02-19-4 SEP 02 Starting System - Starter Failure/Ignition Lock Sticking
02-17-6 SEP 02 A/T - Inadvertent Shift Interlock Disabling
02-16-4 AUG 02 Audio System - Whining/Buzzing Noise From Speakers
02-4-5 FEB 02 Battery - Charging Tips and Guidelines
02-1-4 JAN 02 Engine Head Gasket - Approved Replacement Procedures
02-1-6 JAN 02 Wheels/Tires - Road Force Measurement Equipment
01-24-6 DEC 01 Engine - Oil System Priming Procedures
01-23-6 NOV 01 Engine Coolant - Propylene Glycol Recommendations
01-21-6 OCT 01 Hood Lamp Switch - Revised
01-21-13 OCT 01 Ignition Switch - High Turning Effort/MIL ON/DTC's Set
01-15-7 AUG 01 A/T - Fluid Application Charts
01-15-6 AUG 01 Heater Core - Repeated Failure
01-10-12 MAY 01 Wire Harness - Terminal Repair Kit
01-9-5 MAY 01 Air Cleaner - Lack of Power
01-9-7 MAY 01 Emissions/Engine Controls - Driveability Diagnosis
01-7-3 APR 01 Fuel Pump - Whine Heard Through Radio Speakers
01-6-2 APR 01 PATS System - Diagnostic Service Tips
01-4-4 MAR 01 Diesel Engine - No Start/Rough Idle/No Power
01-4-9 MAR 01 Front Brakes - Pad/Caliper Rattle on Bumps
01-3-2 FEB 01 Steering/Suspension - Stiff, Wandering
01-2-5 FEB 01 Seat Belts - Warning System Operation
00-25-4 DEC 00 Cruise Control - Bucking/Surging
00-24-4 NOV 00 4R100 A/T - Fluid Overheats, Updated Cooler
00-23-10 NOV 00 A/T - In Line Fluid Filter Kit
00-22-1 OCT 00 Engine - Knocking/Cackle Noise
00-21-5 OCT 00 Reverse Park Aid - Proximity Sensor Malfunction
00-17-4 AUG 00 Fuel Injection - High Control Pressure (ICP)
00-9-6 MAY 00 Windshield Wipers - Operate While Switch is OFF
00-6-10 MAR 00 Special Tools - Injector Performance Analyzer
00-3-8 FEB 00 A/T - E4OD/4R100 Fluid In-Line Filter Kit
99-25-10 DEC 99 Glow Plug Control Module - Revised Design
99-22-2 NOV 99 Wire Harness - Terminal Repair Kit/Wire Splice Procedure
99-21-11 OCT 99 A/T - 4R100 Orange Service Tag Service Procedure
aKa The TRACTOR
Smokem' if you can!!!!
VETTKLR
• Borger, TX, USA
• Registered on 4/14/2004
• 14 posts
Posted:7/14/2004 22:22
Damn, Don! That's a lot of stuff going wrong there!
We just replaced the headlight switch in our '00 X. I guess I need to print this page up and take it to the Ford House?
How do I go about having all this stuff looked at, Don?
Thanks for the post! I guess Ford tries to keep this stuff hush hush until something actually goes wrong. I wonder if they'd let you know there was a TSB about a problem or just charge the hell out of you? Nobody said a damn thing about TSB's when my wife was calling all over the place looking for a new headlight switch.
glenn z
• harrison twp., MI, USA
• Registered on 8/22/2003
• 63 posts
Posted:7/15/2004 08:29
there is a differnce between a recall TSB and a general TSB, the recall TSB is when they send out bulletins, the general is if you or i go in with a complaint they look up the list of TSB to see if there has been an issue,
the general TSB do not indicate that there is a problem with every truck, as a recall TSB is
www.mtrperformance.com
