Home/ Forums/ SuperMotors Community Discussion/ Engine and Drivetrain/ 427or 428????
427or 428????
3 posts 3 contributors 2,136 views
PM
Paula MooreOP
  • Member since Aug 2004
  • Sterling, VA, USA
Sep 8, 2004 at 9:31 PM
Hi can someone tell me witch is a better engine, the 427or 428 it will go in to an Australian xb falcon and what 4speed trans should go behind this engine?
Paula
GN
Glenn N
  • Member since Sep 2003
  • Fairfield, CT, USA
Sep 26, 2004 at 6:43 AM
Well they are both very good engines but I'd have to say the 427 has the edge over the 428. Larger bore, crossbolted mains, larger block oil passages etc.... Most run a toploader tranny for a 4 speed. They are far more durable than the older T-10's. G.
T
Ted E.
  • Member since May 2003
  • Central Texas, TX, USA
Dec 19, 2004 at 2:17 PM
For a street application, the 428 would be more ideal with it's longer stroke and small bore thus having "more seat in the pants" or torque at the lower commonly driven rpms. If you'd like the best of all worlds, use the 427 block with its larger bore in conjuction with the longer stroke 428 crankshaft for an easily built stroker.
Ted.
