Home/ Forums/ Car and Truck Make and Model Specific/ Bronco, Bronco II/ Back window
Bronco, Bronco II
Back window
3 posts 2 contributors 2,997 views
JT
JOE TEPOSTEOP
Jan 30, 2005 at 9:09 PM
Here's my issue I have a '93, the instrument panel witch that rolls the back window down will only roll down, all the other windows work fine, if I walk around and use the key on the rear door it goes both ways. Is it the fuse, or is their a relay I'm missing here. I'd appreciate any help. I need to post my bronc she looks sweet, all it took was a lift, some mickey's and a python now she rocks.
ST
stangmata50l
Feb 10, 2005 at 12:43 PM
This is probably way to late but i was playing around here and found this.
The first step is to pull the switch out. Check for dirty connectors or a wire that has come off the switch. There are six (IIRC) wires on the back of that switch.
If that doesn't work, grab yourself a multimeter and check continuity or short the wires to let the window motor get power. If it does, new switch time.
JT
JOE TEPOSTEOP
Mar 29, 2005 at 10:09 PM
Ian, thanks I actually took the puppy out and took the thing apart, it worked for about a week and then went out again, so I'm guessing it's either the swith or a relay I'm missing. I can use the rear switch without a problem. Thanks I appreciate your help.
