Home/ Forums/ Car and Truck Make and Model Specific/ Bronco, Bronco II/ Vibration Problem
Bronco, Bronco II
Vibration Problem
15 posts 6 contributors 7,735 views
BO
Brian OlsonOP
  • Member since Mar 2003
  • 11 posts
  • Birmingham, AL, USA
Mar 14, 2003 at 10:43 PM
I just bought a 1993 Bronco XLT with the 351 and E40D, truck has 110,000 miles, and has never been wrecked or lifted. Everything appears to be stock, but there is a harsh/severe vibration, clearly from the rear of the vehicle, which I have not solved with new U-Joints in the rear drive shaft. Always there under light load, but rears it's ugly head under heavy load from 45-55mph, and under constant load from 70-80mph,predominantly under load and acceleration up a hill. Already tried to shim the rear end above and beyond what looks like 7 degree factory wedges in place, to eliminate pinion angle problems, helped slightly at 20-45mph speeds , but no effect at higher speeds. Anyone with any experience with an apparently factory Bronco, please help !!!
DS
Don Stith
Mar 15, 2003 at 7:57 AM
I had a vibration in my 93 same set up. The vibration wasn't there while it was in third or overdrive but occured only when the tranny was shifting between the two gears. Torque converter was the culprit. Hope this helps. Don
BO
Brian OlsonOP
  • 11 posts
Mar 15, 2003 at 8:21 PM
I appreciate the info, what exactly is the problem with the torque converter, and what are the causes ? Milage, design problem, did you go back with a converter from the dealership, aftermarket ?
MA
massbronco
Mar 16, 2003 at 6:19 PM
i had same vibration from the rear. i replaced the u-joints on the double carden yoke that seemed to be the problem in my case
just my 2 cents
good luck
BO
Brian OlsonOP
  • 11 posts
Mar 17, 2003 at 12:34 AM
Changed all three ujoints in rear drive shaft this weekend, no results .......have heard that the ring gear bearin may wear and give vibration, any experience out there with this ?
MA
massbronco
Mar 23, 2003 at 5:46 PM
did you check the double carden ball assembly for wear? if it is worn you may get some vibration.
johnb
JR
Jason Rich
Mar 24, 2003 at 4:57 PM
Just a but of more advice. Check the rear driveline itself, It may be bent or warped causing vibrations at high speeds. Hope this helps.
MA
massbronco
Mar 25, 2003 at 11:05 PM
hey jason
that happened to my 80 bronco don't know why i didn't think of that before.
my spring perches were bent 1/4" into axle tube from pullng hole shots on pavement with 36" mudders. had a buddy weld some beads on til i could grind it down level put block back on and i was set.
john
BO
Brian OlsonOP
  • 11 posts
Mar 26, 2003 at 4:07 AM
Hey guys, I changed the trans/torque converter fluid and filter and the vibration is 95% gone! Wasnt all that dirty, but did it ........now only hear a rhythmic slight roar when trans is under load at freeway speeds up an incline. Probably indicative of trans rebuild or new torgue converter as suggested in my near future, but She's gonna have to run for awhile! Appreciate all the help !
BR
BroncoHound
Apr 30, 2003 at 9:11 PM
Hey Brian,
Where in Bham are ya? I live here to and have an 86 full size doing the same thing.
The guy I bought it from said that I need to change out some valve or something? I cant remember. anyways if anyone knows what valve he was talking about let me know. But Brian email me and maybe we can hook up and good mudding one weekend.
[email protected]
[email protected]
edited Apr 30, 2003 at 9:13 PM
