Max Temps & Boost
Thread Statistics:     Users to Post: 3   |   Total Posts: 5   |   Total Views: 730
Brandon Reid
• El Mirage, AZ, USA
• Registered on 3/6/2005
• 9 posts
Posted:3/27/2005 22:49
Well I finally got my gauges installed along with a MBRP Exhaust. I know I've seen the max temps and boost numbers on here 100 times but i'm having no luck with the search tonight so a little help would be appredciated alot!
I put the egt sensor pre-turbo and basically followed the dieselmanor.com install sheet except i used autometer gauges.
I did the gauges on the pillar, theres a pic here, i think they turned out really nice.
I also just did a 6" lift with 35" tires & 20" rims if any of that matters.
I use my truck for DD during the week about 60 miles a day RT and tow my appx 4000# jeep around on the weekends.
Posted:3/28/2005 07:51
The Excursion looks great Brandon! For the 6.0L's I'd keep the Maximum EGT's around 1,250-1,300 and the normal Maximum Boost psi's will be around 28-30 stock but can go as high as 35+ with a tuner or hot chip.
We'll hafta hook up in mid-late May when we're in Gilbert to check out your 2005 X if your around
FamilyRideII
• Flower Mound, TX, USA
• Registered on 8/7/2003
• 51 posts
Posted:3/29/2005 21:31
With mine I see 26 or so max stock and as hig as 32-33 wiht the SC 1704. EGT's I've never seen higher than 1100 "maybe". As CHPmustang said though, hotter modules and maybe a couple of tuners can get you much higher EGT's
2004 Eddie Bauer Excursion
4x4 6.0 PSD, all the goodies, Superchips 1704, Magnaflow, Isspro Gauges, 285 REVO's
Brandon Reid
• 9 posts
Posted:3/29/2005 22:14
thanks for the numbers guys, sounds like i'm doin ok so far.
bill, let me know when you are gonna be around. are you bringin your X?
i'd like to check out that bumper of yours
Posted:3/30/2005 08:42
Yeap Brandon we'll be taking the Excursion out west in May-June
In late April I'm going to work on organizing a get-together and hopefully our plans don't change a week before we leave here like they did this past January
Max Temps & Boost
