Serpentine Belt - 6.8
Thread Statistics:     Users to Post: 4   |   Total Posts: 13   |   Total Views: 2891
EricInWI
• Kenosha, WI, USA
• Registered on 9/18/2004
• 7 posts
Posted:4/4/2005 21:17
Can anyone recommend an upgrade for the stock serpentine belt on the V10, I have a 2004 with the 6.8 and the belt squeals like a stuck pig when shifting at ....well, ...higher RPMS....
I had heard my buddy speak highly about the Gatorback from Goodyear on his little F150 Triton, but can't get a part number for the 2004 V10. Anyone have any suggestions? The local Goodyear Svc Mgr was less helpful than an Autozone employee at closing time
Thanks in advance!
Eric
Posted:4/4/2005 21:45
Eric I pulled up the part number for the Goodyear Poly-V belt but it is for a 2003 not sure if it'll be the same for 2004 models.
#4060990 (Poly-V, w/AC)
Some have used belt dressing but I've found in some cases to make it worse and not fix the problem,I'd suggest a new belt altogether.
I don't get my head under the hoods of many V10's but I'd check the idler pulley/tensioner to be sure it's not cocked or any of the other belt driven components.
birdman127
• baltimore, MD, USA
• Registered on 10/13/2002
• 581 posts
Posted:4/6/2005 06:42
I also just replaced my belt with a Gatorback belt before leaving for Florida for two weeks and no noise or problems. It was a easy job with a tool from AutoZone in there parking lot.
Moderator
2000 ltd 6.8 V10*4.30LS*
Lots of mods
check my gallery
Posted:4/6/2005 10:22
Scott what tool is needed to crank on the tensioner to get the belt on and off? I know on the 7.3L's we use a 1/2" drive breaker bar.
Posted:4/6/2005 10:30
CHP, you recommended belt dressing.....
remember the word moderation if you use that stuff
let's say a "buddy" years ago was embarrased by the squeal in his NICE Jeep 5.9 Limited...
let's say he tried some belt dressing and used the ole logic...
"If a little does good, a lot will do betta"
let's say that SOME slip is preferred...
cuz the belt SNAPPED about two blocks down the road because of TOO much grip
edited 4/6/2005 10:30
Posted:4/6/2005 10:55
Yeah when I see the cans of belt dressing in the auto parts store it sorta makes me cringe but it is a quick band aid but not a long term fix in any way so yeah use that stuff in moderation.
Too much slip and the belt/s will glaze from the heat then crack then snap,proper tension is the best measure for long life on belts.
EricInWI
• Kenosha, WI, USA
• 7 posts
Posted:4/6/2005 16:10
CHP, and all,
The Goodyear part number 4060990 is for the six rib 99" long Gatorback. It is the same for the 2004, and OH MY FREAKIN GOD WHAT A DIFFERENCE!!!!!!!!
Took about 10 minutes to install.. had to find something to stand on No squeal during upshifts, and I swear it is quieter at idle. $29 bucks well spent, I even got one for the wife's explorer.
Thanks for all the input!
Posted:4/6/2005 16:21
Hey Eric,where'd you pick up the new belt at?
Glad to know the problem is resolved
EricInWI
• Kenosha, WI, USA
• 7 posts
Posted:4/6/2005 17:32
Autozone, they had the 99 in stock for the Ex, but had to special order the Explorer belt. Goodyear wanted $54 for special order.
Posted:4/6/2005 18:08
Goodyear direct sure is abit more than the Autozone route
Thanks for the comeback Eric
